Squaring my Incra Miter Gauge with a Micro Adjust Jig
Forum topic by Jeremy Greiner posted 04-30-2012 01:28 AM 5735 views 2 times favorited 9 replies Add to Favorites Watch
View Jeremy Greiner's profile
Jeremy Greiner
568 posts in 2766 days
04-30-2012 01:28 AM
Topic tags/keywords: jig
I just bought an Incra Miter gauge because my miter gauge is “wobbly” in the miter slot and has not adjustments to make the miter bar fit better. So I had hoped that it’d be square right out the box, but no such luck. Not a big deal, I’m sure such an object bouncing around in shipping and so forth it would be unreasonable to expect it to be but I can always hope right?
The miter gauge has 4 mounting screwed for the front bracket to allow you to adjust it to be perfectly square at the 0 mark on the gauge. I used an aluminum square to square the miter gauge to my miter slot as recommended by newwoodworker.com http://www.youtube.com/watch?v=NrTeFQ0iQ5k&feature=g-all-u
After that I checked it using the 5 cut method a lot of people use for cross cut sleds it it was really close, but 3/128th’s after 4 cuts seemed like a bit high (I know it gets divided by 4 so the error is less than 1/128ths but I felt I could do better).
For a while I had all the screwed loose except the 2 edge screws which I would use the adjust the sides to try and get closer to square. I’d unscrew one side, tap it lightly and all it all that sucked. It just wasn’t predictable enough, what I needed was a micro adjustment type system.
So I made one!
The jig is just a piece of purple heart scrap that I drilled 2 holes into. One to mount the wood to the miter gauge and another for a t-nut that I put a t-bolt through with 2 normal nuts tightened together at the end.
First I tapped the right side of the miter gauge so that it was too close to me, then I used the micro adjust to slowly creap up on a square. It took a while and a lot of patience but I slowly crept up on it and got it about as close to perfect as I’m going to get.
I used the 5 cut method, with an 8’’ piece of MDF and the 5th piece was less than 1/128th of an inch difference (my fractional digital caliper only goes to 1/128ths difference). So that means that over 32’’ the error is less than 1/512th’s of an inch.
That’s close enough for me :)
-jeremy
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
9 replies so far
View rance's profile
rance
4258 posts in 3155 days
#1 posted 04-30-2012 01:38 AM
Jeremy, First of all, you need to add a sacrificial fence to the front of the miter gauge. When you do, THAT is where you do your micro adjusting(using tape). I believe that is what incra recommends too. Have you contacted them about the inaccuracy? That should be one of your first steps. I think once you have this figured out, you will REALLY like this miter gauge.
Jeremy Greiner
#2 posted 04-30-2012 01:40 AM
Hi Rance,
I do have a fence for it already, but I wanted the root of it to be square first. The 4 mounting screws allow for this adjustment. Any inaccuracies in the fence, I’ll fix with the fence. But starting with an non-square miter gauge didn’t seem to make much sense.
-jeremy
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#3 posted 04-30-2012 01:53 AM
Thanks for the post Jeremy
When you say the 4 mounting bolts, are they the ones with the hex head?
TIA
Jeremy Greiner
#4 posted 04-30-2012 01:57 AM
Yes, looking at my first picture it’s the 4 screws with the allan wrench heads.
The instructions with my miter gauge said to loosen these screws and use a square to square the gauge to the blade, I just took it to the extreme :P
-jeremy
rance
#5 posted 04-30-2012 02:16 AM
Well doooh on my part. :) So why can’t you use those 4 bolts to get it square? You are right, that is the way to do it, then deal with the fence inaccuracies in a separate issue.
Jeremy Greiner
#6 posted 04-30-2012 02:29 AM
Those are just mounting screws, you unscrew them, wiggle the faceplate around to get it square. Well the “wiggle” method wasn’t good enough .. so I made this jig to adjust the face. then once it’s square you tighten down the 4 screws and it’s locked in.
View Sawkerf's profile
Sawkerf
1730 posts in 3063 days
#7 posted 04-30-2012 03:20 AM
Jeremy -
Having a perfectly square “root” is pointless if your fence is off by a bit. You need to set up your miter gauge as you plan to use it and make your adjustments from there.
If you’re under .007” at the “root”, take it and run. Put on your sacrificial fence and square up on it. Keep in mind that you’re working with wood. Just changing the way you grip your workpiece will change the perfection of your cuts.
View Bill White's profile
Bill White
4928 posts in 3955 days
#8 posted 04-30-2012 01:37 PM
I’m gonna send my 1000SE to Jeremy. Well probably not ‘cause I just set mine up with a drafting square.
Good post Jer. Thanks.
Bill
-- bill@magraphics.us
View Hard_as_Wood's profile
Hard_as_Wood
28 posts in 936 days
#9 posted 03-02-2016 07:16 PM
What did you mean by a piece of tape?
Are you using tape at the end of the fence to act as a shim?
-- Ciao!
