My first Lathe
Forum topic by MikeOB posted 04-29-2012 12:32 PM 1519 views 0 times favorited 19 replies Add to Favorites Watch
View MikeOB's profile
MikeOB
89 posts in 3088 days
04-29-2012 12:32 PM
Started thinking about buying my first lathe…since I have not turned 1 thing before I was thinking of taking a beginners class…but anyway. I found this…
a Rockwell 46-111 for $235…
is this a good deal? is it a model I would not be able to get parts for? should I stay away from this one since I’m a newbie at it?
any suggestions would be great…thanks
-- Mike, Portage, WI
19 replies so far
View dhazelton's profile
dhazelton
2756 posts in 2264 days
#1 posted 04-29-2012 12:38 PM
At first blush it sounds a bit high, but if it is plug and play with all the accessories….or does it need a stand and restoration? I’d look here for comparables:
http://vintagemachinery.org/mfgindex/detail.aspx?id=1191&tab=4
MikeOB
#2 posted 04-29-2012 12:43 PM
this is what it comes with:
wood lathe with stand, excellent shape. 36 X 11 inch spindle capacity, 14 inch inboard faceplate capacity. Out board turning available with appropriate faceplate. 4 speed, belt driven. Comes with spur drive, dead center, live center, 3 tool rests, manual, wrench, small faceplate and leather padded anchor boards
MikeOB
#3 posted 04-29-2012 12:46 PM
http://madison.craigslist.org/tls/2962936780.html
here is the post with a pic
16274 posts in 4186 days
#4 posted 04-29-2012 02:03 PM
Sounds like a very good deal to me. I’d jump on it if I were you.
View Bluepine38's profile
Bluepine38
3379 posts in 3053 days
#5 posted 04-29-2012 02:22 PM
This is one of the old sturdy gap bed lathes, so called because of the gap between the headstock and the
start of the rails that allows you to turn slightly larger short bowls and plates. The bearings in the headstock
are easy to replace and the manual will tell you how to do this if it is necessary. I have a similar lathe without
the gap bed and with a couple of the combination right hand/left hand threaded face plates that are difficult
to come by. The threads on the drive should be 1”-8TPI right hand on inboard and left hand on the outboard.
Those anchor boards look like they are made to be inserted between the lathe bed and the bench to raise
the rails. This will make it easier to reach under the rails and attach and remove the tool rests and other
accessories. In my opinion it is a great starter lathe at that price and will give you great service.
View robbiethewood's profile
robbiethewood
124 posts in 2212 days
#6 posted 04-29-2012 02:23 PM
hi looks OK a couple of things you would want to check the bearings the belt and the motor if the guy that is selling it lets you try before you buy that would be great looks like its coming from a good home from here great little starter lathe
-- http://robbiethewoodturner.net/
View waho6o9's profile
waho6o9
8167 posts in 2544 days
#7 posted 04-29-2012 03:07 PM
And a first good lathe it is, I would buy it. Maybe it comes with more than one turning tool?
You’ll have to learn how to sharpen the turning tools as well. Good luck Mike.
View nick85's profile
nick85
39 posts in 2214 days
#8 posted 04-29-2012 04:39 PM
I would jump on it quick before it’s gone! Granted I got my first lathe for free by digging it out of a shed, but I’m already wishing I had something like the one you posted. Most lathes similar to that are going for $300+ around here, and don’t come with any of the extras… =(
-- "I suggest a new strategy, R2: let the Wookiee win."
MikeOB
#9 posted 04-29-2012 10:41 PM
he told me the lathe is 25+ years old but in very good shape. What does a lathe like this cost new? just curious..
View David Kirtley's profile
David Kirtley
1286 posts in 2965 days
#10 posted 04-29-2012 10:59 PM
The only negative thing I would say is that I personally prefer a variable speed lathe. Other than that, it sounds like an good deal. Looks to be barely used.
As far as price, something new in that caliber you are leaving the store at least $500 poorer minimum.
MikeOB
#11 posted 05-02-2012 01:36 AM
I ended up buying it!
David Kirtley
#12 posted 05-02-2012 01:33 PM
Thanks for letting us know. Usually people don’t bother and just leave us hanging. :)
Enjoy it. Lathes are a lot of fun.
robbiethewood
#13 posted 05-03-2012 10:58 AM
good luck whit your new adventure
nick85
#14 posted 05-03-2012 01:31 PM
Quick tip from someone else who just started turning:
SHARPEN YOUR TOOLS BEFORE ANYTHING ELSE!
I figured mine were sharp enough, but no, piece of palm whacked me right in the face… =S
Other than that, it’s a lot of fun, and a little hypnotizing at times…
View ratchet's profile
ratchet
1391 posts in 3754 days
#15 posted 05-03-2012 01:35 PM
Be sure you where a full face shield and learn the safety procedures before you get started. You can seriuosly whack yourself with these things.
