Help Choosing Joinery for First Project
Forum topic by Texchappy posted 04-28-2012 05:40 PM 1611 views 0 times favorited 19 replies Add to Favorites Watch
View Texchappy's profile
Texchappy
252 posts in 2221 days
04-28-2012 05:40 PM
First woodworking project period and I plan to do a utilitarian piece – a box for my old Torque wrench. From the advice given me on another thread, I think I’m going to use poplar. My next decision is how to join it up. I thought about doing dovetails but I’m not sure that isn’t too much of a leap for my first project. Not sure I’d want to do a simple miter or butt joint either.
So what would you recommend for joinery for a first project? Also need to figure out bottom and lid so ideas on that would be helpful tool.
I will be doing this by hand. I’d like to do something like this bot not sure I could do it at first: http://www.daikudojo.org/Archive/howtos/20070224_toolbox/
-- Wood is not velveeta
19 replies so far
Craftsman on the lake
2791 posts in 3438 days
#1 posted 04-28-2012 05:46 PM
Finger joints look good on a box, especially a longer one and are doable for a first time joinery project.
View BTimmons's profile
BTimmons
2303 posts in 2486 days
#2 posted 04-28-2012 05:50 PM
Get the poplar and try a few practice joints, perhaps different types as well. That way when you’re ready to tackle the toolbox (which shouldn’t be too long), you’ll go into the project with more skills and confidence.
-- Brian Timmons - http://www.BigTWoodworks.com
View David Kirtley's profile
David Kirtley
1286 posts in 2998 days
#3 posted 04-28-2012 06:13 PM
Hand cut finger joints and those through tenons on the link are a lot harder to make come out nicely than dovetails. Dovetails are a lot more forgiving. Just watch some videos.
Paul Sellers does a good job explaining:
Make sure your stock is square. Layout carefully and take your time. Use a knife line to lay out. Clearly mark which is waste and what stock stays. Keep clear of the lines when removing waste. Pare carefully to line with the chisel. Do a couple practice runs first on some scrap stock.
You will mess up a few times. You will cut the tails and leave the waste a few times. You will cut them backwards a couple times. Don’t worry about it and after a few sets, it will become second nature.
Texchappy
#4 posted 04-28-2012 06:19 PM
Thanks for the ideas. I might just give dovetails a try – been watching videos for 2-3 days on doing them. Hadn’t seen the Sellers video so thanks for that.
Any ideas for the lid and bottom other than just butt jointing (?) it to the bottom and top (with a couple of cleat boards)?
View ShipWreck's profile
ShipWreck
557 posts in 3753 days
#5 posted 04-28-2012 06:21 PM
Good luck and have fun with whatever you decide Tex :)
Texchappy
#6 posted 04-28-2012 06:30 PM
From watching that videos and others – Alright, so it should take me about ten minutes – no problem ;)
David Kirtley
#7 posted 04-28-2012 06:34 PM
Small boxes, you can nail and glue flush, rabbet, or groove for a thinner panel. Larger stuff gets a bit more complicated- but not much.
Paul’s video goes through the whole process. Will be a great starting place.
David Kirtley
#8 posted 04-28-2012 06:35 PM
Texchappy,
No, the first one will take as much as all day. When you see them do it in 10 minutes, you get that fast after the first thousand. ;)
View waho6o9's profile
waho6o9
8191 posts in 2577 days
#9 posted 04-29-2012 07:29 PM
Texchappy
#10 posted 04-29-2012 07:38 PM
waho6o9: that looks a lot like what I’m after. Are those half-lap joints on the corner? I like the look of the sliding lip but wasn’t sure how to do it with out plane of some sort to cut out the groove.
waho6o9
#11 posted 04-29-2012 07:43 PM
I think they’re called rabbit joints. You can chisel the grove for the sliding top. It will give you good practice and you will learn about grain and the sharpening of your chisels.
You can do it.
Texchappy
#12 posted 04-29-2012 07:48 PM
Thanks waho6o9. So bench chisel to remove the majority and then pare (?) it out. I only ordered a 1/4” bench chisel, can I use it for the paring or is this a case of the right tool for the right job for the right result.
waho6o9
#13 posted 04-29-2012 07:53 PM
Your welcome Texchappy.
Yes, take your time and don’t smack the slot (1/4” dado) too hard or it will split the board. I am an expert at that.
Texchappy
#14 posted 05-04-2012 02:17 AM
What thickness of board should I use for this project?
waho6o9
#15 posted 05-04-2012 03:55 AM
Let’s see. Your torque wrench is not too heavy. So, I would suggest 3/4 ply or 3/4 softwood as you will be using hand tools from what I understand.
Or, 1/2 poplar might suffice, and hopefully it wouldn’t be to difficult to work with hand tools.
Maybe others might suggest a different type of wood as well.
4/4 ( four quarter ) lumber would be more than enough.
