Need to drill 2 3/16" holes for recessed cabinet lights.
Forum topic by noone posted 04-28-2012 03:42 PM 4489 views 0 times favorited 8 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2175 days
04-28-2012 03:42 PM
I need to drill 2 3/16” holes for recessed cabinet lights. The closest hole saw I can find is a 2 1/8” or 2 1/4”. How do you cut your holes? Maybe the 2 1/4 would work since there are clips.
Light-
http://www.hafele.com/us/external/catalog/pages09-02/1088W.pdf
8 replies so far
View Wdwerker's profile
Wdwerker
333 posts in 2136 days
#1 posted 04-28-2012 03:47 PM
Make a jig with a flywheel cutter in the drill press (adjustable to any size) then clamp the jig in place and cut with a router and pattern bit with a router. Might be easiest to drill the hole undersized and route it to full size.
-- Fine Custom Woodwork since 1978
View Bill1225's profile
Bill1225
125 posts in 2302 days
#2 posted 04-28-2012 03:50 PM
I use a hole saw on job sites ( spin it in reverse to avoid tear out on surface then switch back to forward) in the shop I use a forstner bit
noone
#3 posted 04-28-2012 03:51 PM
Nevermind. The 2 1/4” should work perfectly. 2 3/16 you wouldnt even be able to get the clips in the hole!! Doh!
View SnowyRiver's profile
SnowyRiver
51457 posts in 3383 days
#4 posted 04-28-2012 03:52 PM
I use a hole saw attachment for my drill. One of the best hole saws is Lenox. They make them in the size you are looking for. They arent cheep, but they really work well.
http://www.lenoxtools.com/Pages/Category.aspx?category=HOLE+SAWS
Lowes usually has them.
-- Wayne - Plymouth MN
View Sawkerf's profile
Sawkerf
1730 posts in 2971 days
#5 posted 04-28-2012 04:01 PM
I would use the 2 1/4” hole saw. That would give you all of 1/32” “slop” between the wood and the light.
View woody123's profile
woody123
53 posts in 3209 days
#6 posted 04-30-2012 03:08 PM
For small holes I use my router by drilling a hole in my router base push a rolled pin or nail or screw into the hole and pivot the router around until the hole is cut to size. You can also use a commercial base like this:
http://www.woodcraft.com/Product/2003582/9031/Jasper-Circle-Jig-Small-1--712.aspx
My .02
View Carl Webster's profile
Carl Webster
82 posts in 2701 days
#7 posted 04-30-2012 07:41 PM
A 2 1/4 ” hole saw is the easiest and fastest approach.
-- Carl in SC
View woodman88's profile
woodman88
143 posts in 2551 days
#8 posted 04-30-2012 10:38 PM
I also would use the 2 1/4 hole saw which gives you alittle room but will be fine I am sure the lights have some sort of trim ring
