Marking gauge or pencils.
« back to Hand Tools forum
Forum topic by ShipWreck posted 04-28-2012 02:02 PM 1403 views 0 times favorited 7 replies Add to Favorites Watch
View ShipWreck's profile
ShipWreck
557 posts in 3833 days
04-28-2012 02:02 PM
I seem to be going back and forth between a No.4 pencil and my wheel gauge. What method do you LJ’s use?
V/R….. John
7 replies so far
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15440 posts in 2698 days
#1 posted 04-28-2012 02:36 PM
Depends on the task, what gets used. And the lighting at the time…
View Lee Barker's profile
Lee Barker
2170 posts in 2930 days
#2 posted 04-28-2012 02:49 PM
I treat them as too different tools, John. Pencil (I use 2.5 Dixons) allows me to write communications on parts, cross out an erroneous mark, and, most often, scribe a line from a straight edge of some kind. Pencil marks, though less precise than a scribe mark, can be erased or eliminated with rubbing alcohol or lacquer thinner.
The gauge, or scribe, does its thing by making marks parallel to other surfaces. Invaluable.
Your interest in markage suggests to me you might enjoy making a striking knife. It’s a half hour joyful task briefly described and illustrated here.
Pencils by far get the most use because they’re handy in my Pete Wadey Apron.
A side benefit of pencilis: I have disciplined myself to stop and ponder things when I’m sharpening them. For me, it’s a time to say, usually out loud, hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm.
I like discussions about humble, simple tools. I will enjoy the LJ responses to your post.
Kindly,
View helluvawreck's profile
helluvawreck
31966 posts in 2947 days
#3 posted 04-28-2012 03:10 PM
I use both but most often it’s a sharp no 2 pencil. My eyes are not what they use to be so I have to be careful and take my time that I don’t miss the mark.
helluvawreck aka Charles
View Sawkerf's profile
Sawkerf
1730 posts in 3149 days
#4 posted 04-28-2012 03:35 PM
I use 0.5 or 0.7mm mechanical pencils. It’s too easy for me to confuse a scratch or nick with a “mark”. Pencil marks are easy for me. – lol
View Martyroc's profile
Martyroc
2712 posts in 2386 days
#5 posted 04-28-2012 04:49 PM
I use both, my go to is the pencil, unless its very intricate work than the scribe is really the only way for me. When I did my Kitchen cabinets I used the scribe, the last project I used a pencil. I guess it all depends on what your doing, scribe would be more accurate, but I do a lot of outdoor stuff and the pencil works fine for that.
-- Martin ....always count the number of fingers you have before, and after using the saw.
View NiteWalker's profile
NiteWalker
2737 posts in 2657 days
#6 posted 04-28-2012 05:22 PM
I use #3 ticonderogas.
I prefer the harder lead as it leaves a finer line and stays sharper longer. What helps a lot is getting into the habit of scribing a line once instead of going over it several times.
View TDog's profile
TDog
235 posts in 2310 days
#7 posted 04-28-2012 05:31 PM
I am switching to a marking gauge and knife now.
I was using a fine tipped pencil. Here are my thoughts why.
Pencil Cons
1. to much sanding needed later
2. line width begins to vary as lead wears down
3. lead breakage
4. chisels and saws do not grab the pencil line
5. to much sanding later
Gauge and Knife Pros
1. Fine line without coloring wood
2. Chisels and saws find lines easily
3. Easier working between Dovetails
4. Low maintenance
5. there are some really cool marking gauges and knifes out
-- "So many projects...so little time..." Psalm 23
