Hole in the wall
Forum topic by plang posted 04-25-2012 08:23 PM 953 views 0 times favorited 4 replies Add to Favorites Watch
View plang's profile
117 posts in 3286 days
04-25-2012 08:23 PM
The home I currently own has a hole in the wall in the garage from the previous owners anger issue. Anyway, I thought instead of repairing it I would cut out that section and build in a shelving unit to house some tools. My issue is it is a wall that leads into the house and it is insulated. I am just game to do it but the wife is a stickler and wants to replace it with something. I do not want to loose the dept so what would you suggest? P.S. There are no pipes or electrical wires in this space. Thanks
View derosa's profile
1572 posts in 2767 days
#1 posted 04-25-2012 08:41 PM
Patch the hole and go over the top and cut a hole in one of the other walls if they aren’t insulated, only do it if you have a heated garage and the lack of insulation won’t make a difference.
-- --Rev. Russ in NY-- A posse ad esse
View dbhost's profile
5687 posts in 3164 days
#2 posted 04-25-2012 08:55 PM
Patch the hole, build a cabinet to suit your needs and mount it to that said wall via a french cleat. Make sure you use nice strong screws in the cleat and screw into the studs. Going into the wall cavity will reduce the effectiveness of the insulation.
-- My workshop blog can be found at, YouTube Channel
View Sawkerf's profile
1730 posts in 3000 days
#3 posted 04-25-2012 11:30 PM
That wall may be a firewall which must provide a certain amount of time before a fire can burn through and into the house. Removing drywall reduces the fire rating. I’m betting that it has 5/8” drywall instead of 1/2”.
If you’re renting, you definitely want to check with the landlord before you do anything.
-- Adversity doesn't build reveals it.
#4 posted 04-26-2012 03:13 AM
All good advise. thanks, I’ll be patching the wall this weekend.
