What Tool is Needed ...
Forum topic by JP Madren posted 04-25-2012 02:51 PM 1239 views 0 times favorited 13 replies Add to Favorites Watch
View JP Madren's profile
JP Madren
6 posts in 2342 days
04-25-2012 02:51 PM
I am fixin’ to start making a wooden kitchen tool that I have been approved a US Patent on (used as a stirring/flipping/scraping, etc tool) and need to find out “what kind of machinery/cutting tool I will need to cut a 1/4 (or slightly wider) slot in a flat piece of wood that’s around 1/4 inch thick?” It will be important that it can cut cleanly without splinterring, while being controllable at the same. To see one of the tools so you’ll have a better idea of what I am talking about I have it on a website (item is currently not for sale – so I’m not trying to sell anything here – just get some info so that I can manufacture it correctly myself) ...it’s on www.Kitchenstick.com. I know there’s a bunch of guys on here that know their craft and the best tools for the job and that “best tool” is what I want to find. ...thanks – jp madren
-- If I can't help you I won't hurt you
13 replies so far
View Jorge G.'s profile
Jorge G.
1537 posts in 2503 days
#1 posted 04-25-2012 02:57 PM
If you are good with a hand saw, use a japanese dozuki, if not then use the Bridge City Tools joint maker pro, expensive but you will make the cuts in no time and very precise.
-- To surrender a dream leaves life as it is — and not as it could be.
117127 posts in 3605 days
#2 posted 04-25-2012 02:59 PM
It’s hard to tell with out seeing photos but perhaps a router mounted on a shop made fixture.
View dhazelton's profile
dhazelton
2771 posts in 2325 days
#3 posted 04-25-2012 03:52 PM
Scrollsaw with an extremely fine blade.
View jdmaher's profile
jdmaher
430 posts in 2608 days
#4 posted 04-25-2012 03:55 PM
Looks like plunge rout through a 8/4 chunk, rout slot to and through the edge; that’s a pretty simple CNC router operation (you could probably round over one end at the same setup). THEN, cut individual sticks out of the chunk, and bevel the ends.
-- Jim Maher, Illinois
View Bertha's profile
Bertha
13529 posts in 2721 days
#5 posted 04-25-2012 04:06 PM
You might get by with a laminate trimmer (router) like the Bosch Colt (<$100) and a shopmade jig. If you want to throw big bucks at it, you could probably use a Festool Domino. Although an expensive route, Jim brings up a good point. If you’re going to be building a ton of them, the CNC is a consideration.
JP Madren
#6 posted 04-25-2012 04:06 PM
Thanks to both of you. I have talked to a couple of people used to working with wood tools (modern stuff instead of the primitive tools I use making my Doughbowls) ... and a “router table” has come up a few times. I knew that there’s so many visiting this site with a wide variety of interests/knowledge and I am wanting to get what I need the “1st time” and figured you guys would know how to get it done. I’ll have no other use for the tool other than cutting out this “notch” which will simply be used to pull out or push in hot oven racks. The sticks that will be in production are going to be a quarter inch wider than the ones seen on the video with the oven rack notch 4” from the end. The making/shaping of the product will all be done in stages starting with cutting the log into long stips at my sawmill and by having no automation – time is my biggest enemy so having good (safe) equipment to work will be important.
Bertha
#7 posted 04-25-2012 04:07 PM
^I like the Bosch Colt even more for this now.
View DS's profile
DS
2926 posts in 2449 days
#8 posted 04-25-2012 04:16 PM
A 5 ton punch press and a progressive die would make super quick work of these on a mass-production scale.
Progressive dies would allow for continuous processing of the item from log to packaging.
View waho6o9's profile
waho6o9
8209 posts in 2605 days
#9 posted 04-25-2012 04:33 PM
+1 for the Festool Domino. It’ll cut clean slots with no splintering.
Good luck on your endeavors.
View darinS's profile
darinS
709 posts in 2895 days
#10 posted 04-25-2012 06:58 PM
I’ll toss out the obvious answer. If you are using 8/4 stock (per Jim in post #4), why not set up a 1/4 inch dado blade? If there is some splintering on the back side, maybe try to arrange the slices so that you have just a little left over so you can get rid of the splintered part.
Hope that makes sense. I’m not so sure I can follow it, and I wrote it.
Best of luck.
-- They say many people die because of alcohol. They never realized how many of them are born because of it.
View Doss's profile
Doss
779 posts in 2293 days
#11 posted 04-25-2012 09:17 PM
Yeah, i’d say start off with some wide stock, dado it (or route it), and then slice it into sticks.
This seems to be something you’d be better off automating for repeatability and speed. That’s just me though.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View Don W's profile
Don W
18756 posts in 2596 days
#12 posted 04-25-2012 09:24 PM
cut the slot with a dado blade before cutting the 1/4 thick slats.
View DS's profile
DS
#13 posted 04-25-2012 09:28 PM
cutting an angled dado in thick material and following with a ball end mill for the rounded profile, then slicing the chunk into the 1/4” sticks could be one aqpproach.
I’d use an auto-feeder so the dado and the ball mill run as a single continuous operation for efficiency.
