Nickel test
Forum topic by lieutenantdan posted 04-25-2012 12:46 PM 3278 views 0 times favorited 15 replies Add to Favorites Watch
View lieutenantdan's profile
lieutenantdan
176 posts in 2506 days
04-25-2012 12:46 PM
Prior to replacing the granite top on my restored 4511, out of curiousity I performed the “nickel test”. It passed with flying colors. I placed the nickel on each of the four table top mounting points and there was no noticeable movement. Does this mean anything or is it only relevant after the table top is on the saw?
-- "Of all the things I have lost in life, I miss my mind the most."
15 replies so far
View Brandon's profile
Brandon
4152 posts in 3151 days
#1 posted 04-25-2012 01:49 PM
Well, I imagine it’s a good sign. Once you add the top it will have even more mass and vibrate less, I think.
Just curious, are you putting a new top on the saw or an old one?
-- "hold fast to that which is good"
View Sawkerf's profile
Sawkerf
1730 posts in 3268 days
#2 posted 04-25-2012 01:51 PM
The nickel test only means that the rotating parts are running smoothly enough to cause almost no vibration. I’ve seen it done after tuning up engines, too.
View NBeener's profile
NBeener
4816 posts in 3374 days
#3 posted 04-25-2012 01:57 PM
To me, it means you still have at least SOME money.
Today, that’s a pretty good thing !
-- -- Neil
View mveach's profile
mveach
56 posts in 2583 days
#4 posted 04-26-2012 04:58 AM
I have a PC table saw from lowe’s that I can stand a dime on edge, start the saw and then turn it off and when the blade stops, the dime is still standing. The saw is stock.
View davidroberts's profile
davidroberts
1027 posts in 3686 days
#5 posted 04-26-2012 05:10 AM
I have a Grizzly TS I can stand a toothpick on while sawing 8/4 red oak and beating the cabinet with a dead drop hammer. Amazing! Really? Shucks, Naw…
-- Better woodworking through old hand tools.
mveach
#6 posted 04-27-2012 01:13 AM
A picture is worth
davidroberts
#7 posted 04-27-2012 03:52 AM
So now I guess I need to go find my camera, and a scrap of 8/4 red oak. I think I know where I last put my TS. But the toothpick may be a problem. Maybe a flosser. Naw, to easy. Let me think…..
mveach
#8 posted 04-27-2012 05:18 AM
a medium sized splinter should work. I know you’ve got one of those.
View knotscott's profile
knotscott
8146 posts in 3575 days
#9 posted 04-27-2012 05:52 AM
Since the thickness and the edges of the nickels themselves are a significant variable, it really isn’t a very scientific test, and doesn’t prove much. There are other variables too. Passing is a good sign that there’s not much vibration going on, but if the nickel falls, it may or may not mean something. As long as the saw cuts well with low runout, I don’t get too concerned one way or the other.
davidroberts
#10 posted 04-27-2012 05:24 PM
Scott, you’re right. I could be wrong but I believe the last few responses are more about bragging, oneupmanship, and polking fun thereof, rather than actual machine quality. ;+)
View PurpLev's profile
PurpLev
8547 posts in 3848 days
#11 posted 04-27-2012 05:39 PM
I could be way off here -but did you place a nickel on the granite – before you installed the granite on the saw? that wouldn’t really say much.
the idea is to place the nickel on the table top (granite in your case) after it is installed on the saw, have it stand on side, then start the saw running – if the saw has little vibrations then the nickel will not fall. THAT will tell you something
if I got it all wrong- dont mind me ;)
View Charlie's profile
Charlie
1100 posts in 2486 days
#12 posted 04-27-2012 07:40 PM
My Steel City 35990G passes the nickel test, the penny test…..
I see it as an amusing trick when people (who aren’t woodworkers) admire the saw. I place a nickel on it, fire it up, run a piece of 3/4 plywood through it and turn it off. They are amazed.
I don’t think anyone who’s a woodworker would be amazed. If it’s a decent saw, level, no errors in belt alignment, and with sufficient mass… won’t ANY saw pass the nickel test?
davidroberts
#13 posted 04-27-2012 10:54 PM
I prefer cast iron table tops. It’s just my preference and doesn’t reflect on granite tops. But I must admit, the granite tops are purdy, purdy.
mveach
#14 posted 04-28-2012 02:43 AM
yup, David, I guess I did fall into the bragging thing. The point I meant to make as Charlie said, the” nickle test” only shows a lack of vibration and even a cheep saw should pass it. Thanks for grounding me David.
davidroberts
#15 posted 05-01-2012 05:22 AM
Hey mveach, forgetaboutit. Bragging is half the fun. Like my mother use to say, it’s not bragging if you can do it.
