Help with Shop Walls
« back to Coffee Lounge forum
Forum topic by Bureaucrat posted 106 days ago 247 views 0 times favorited 21 replies Add to Favorites
View Bureaucrat's profile
Bureaucrat
48 posts in 134 days
106 days ago
Topic tags/keywords: question shop walls
I am about to finish the walls in my garage workshop. I am trying to decide whether to use 1/2” drywall or to us 7/16” OSB. The workshop will be smallish at 13’ x 21’ but has 10’ ceilings. Which of these choices would you choose? There is only a small difference in total project cost between the 2 choices.
-- Gary, Stoughton, WI, USA
View matter's profile
matter
178 posts in 251 days
106 days ago
Personally, I would go with drywall. It reflects light better for finishing.
I guess a coat of paint wouldn’t hurt either…
-- The only easy wood project is a fire
9039 posts in 304 days
106 days ago
I would go with drywall as well. A little paint and it really lightens up the shop. OSB would not look good painted and it would not reflect light.
View GaryK's profile
GaryK
8482 posts in 470 days
106 days ago
I went with drywall also. You can never have too much light. A lot easier to work with also.
View bbqking's profile
bbqking
234 posts in 205 days
106 days ago
Years ago in Iowa I was working out of a garage shop (25’x25’) and I finished the 2×4 stud walls with roll insulation and 1/4” luan plywood. I sealed them with a coat of KILS and rolled on a high gloss white finish. Trimmed it out with 1×2 pine stained and varnished to suit. A lot easier than installing drywall and you get the same lightening effect. Plus, if you get right on it you can have it done and good to go in a weekend. bbqKing
-- bbqKing, Lawrenceville
View wateroperator's profile
wateroperator
13 posts in 137 days
106 days ago
bbqking has a good idea…......I would go with that or drywall….stay away from the osb, It just doesnt look good as a finish covering…
-- you can prick your finger but ......
View ND2ELK's profile
ND2ELK
2461 posts in 256 days
106 days ago
I just finished my new 14’ X 21’ shop with sheet rock and painted it flat white. Then I put in 4 each eight foot, 4 light florescent lights. The lighting is great! When a guy gets older, you need all the light you can get.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
View Mark Shymanski's profile
Mark Shymanski
503 posts in 194 days
106 days ago
I am in the very slooow process of putting up osb on my shop’s ceiling. Yeah it is hard to paint but was about 75% of the cost of drywall and lighter to put up. I figure if I want a smoother finish I can trowel drywall mud across the dips and hollows, prime paint and presto smooth reflective surface…in theory anyway :-)
-- ....next big purchase is wood for the next project, Mark
dennis mitchell
2933 posts in 796 days
106 days ago
drywall should offer some fire protection
View Catspaw's profile
Catspaw
104 posts in 297 days
105 days ago
I put 5/8” drywall on the ceiling and 7/16” OSB on the walls of my shop. Where ever you go you have something to fasten into.
I have no concern for any fire protection problems and I’m certainly not concerned about how it looks. If you are concerned about fire it’s the ceiling that you have to worry about. It’s neat and tidy if not smooth. If my shop catches fire …. it’s gone. When the showcase of workshops tour comes through I don’t think they’ll think too badly of me…..oh….yea….there IS no showcase tour of workshops. But it sure is nice to be able to screw into the OSB instead of using useless drywall anchors.
-- arborial reconfiguration specialist
View roman's profile
roman
439 posts in 375 days
105 days ago
I cant stand drywall. My house is full of it and full of dents, chips, popped screws. After a year of re-fastening, patching, scuffing, sanding and painting…...........its done….............ever smelt a home done in drywall that isnt heated. .............they smell musty.
Throw a hammer at drywall, or have a kick back on the TS and see how well drywall stands up or get it wet.
Aside from the fire resistance and perhaps better sound retention, in a shop it just looks like crap in no time unless the shop is for show.
Plywood…......you can bang it, hammer it, nail it, put screws in it, hang stuff from it, paint it, glue it, patch it.
I certainly wouldnt waste my money on drywall for a shop….......been there too many times.
Todd A. Clippinger
2536 posts in 581 days
105 days ago
I use my shop professionally and I have sheetrock on it. True, it finishes out nicer. True, it also dents easier than OSB. I plan on using sections of plywood to protect the wall in areas that will receive brutal wear, such as a place to hang the clamps. I don’t regret using the sheetrock.
View SteveB's profile
SteveB
21 posts in 540 days
105 days ago
I did mine in pre-painted white pegboard. It’s nice and bright, and I can move tools stuff around at my whim.
-- Steve B - New Life Home Improvement
View odie's profile
odie
705 posts in 322 days
105 days ago
I didn’t take the time to read everyones responses, but check you local fire codes.
-- Odie, Confucius say, "He who laughs at one's self is BUTT of joke".
View blackcherry's profile
blackcherry
196 posts in 305 days
105 days ago
SHEET ROCK SHEET ROCK SHEET ROCK ….ROCK ROCK ROCK ROCKS ROCKS….BLKCHERRY
View DaveH's profile
DaveH
241 posts in 260 days
105 days ago
OSB ugly!!! I’d either use exterior plywood T1-11 (painted white) or drywall. I did my shop in drywall. I have a 1000 sf shop with 10ft ceilings and paid a professional $700 to hang, tape, and texture. I provided the materials. Worth every penny. Drywall has a much higher fire resistance than OSB or Plywood. Good chance it you cover the ceiling and walls with OSB and a fire breaks out, it will probably be a total loss. Drywall at least gives you a little more time before the structure burns to the ground.
Fire codes in some parts of the country require some type of fire rated material covering the walls near all electrical outlets.
-- Dave Herron, Boise, ID -- “That which does not crash the browser, makes it stronger”
View Dadoo's profile
Dadoo
1536 posts in 472 days
104 days ago
Mine is done in OSB, but the future plans are to add sheetrock and prime and paint. One of those walls I’d like to see T&G pine at a 45 degree angle! Dave’s idea of T1-11 would look real nice as well. OSB is ugly but very strong and you can hang anything anywhere. What I’ve also seen is where house manufacturers will put drywall/sheetrock on top of 3/4” OSB where the future cabinets will hang. (Found it in my guest bath!) It’s great that you don’t have to go stud seeking when attempting to hang things. So I would suggest going with sheetrock but placing OSB underneath where you’ll be hanging your goodies.
Also, OSB won’t pass any fire codes. So if you’re running a proshop you’ll have to have something fire retardant on the surface. But if you’re just a run-of-the-mill old mad scientist, like me, then do what ya want.
View Greg Wurst's profile
Greg Wurst
412 posts in 314 days
104 days ago
You might try some of the white melanine coated MDF slot board you can get at Lowes or possibly HD. Makes for great wall storage. Will certainly cost more than drywall, though.
View knothead's profile
knothead
30 posts in 430 days
104 days ago
My Shop is my 2 car garage it has the required drywall ceiling and drywall adjacent to the house for fire blocking code requirements but the other three walls are insulated and covered with 1/2” plywood that I primed and painted. just as bright as drywall but MUCH more durable and the added bonus of being able to hang all but the heaviest items anywhere you want regardless of stud position, my cabinets and heavy items are attached to studs but everything else is easy.
Just my 0.02 cents worth (0.002 adjusted for the weak dollar)
-- So Much Wood - So Little Time! --
View motthunter's profile
motthunter
1216 posts in 281 days
104 days ago
think about what you may hang on the walls and how. If you sheet with ply you can hang anything anywhere.. with drywall you have to find studs to hang you stuff… I have seen nice shops with tongue and groove pine.. kind of costly but nice and functional
-- making sawdust....
Bureaucrat
85 days ago
thanks everyone for your input. I decided to go with 1/2” drywall. The slower burn argument won me over. Completed 1/3 of the project last weekend. Hope to get to 1/2 done by this coming Saturday.
View EdC's profile
EdC
420 posts in 322 days
85 days ago
you can also get flame retardant OSB and plywood.
That way you don’t have to tape it, spay it with primer than finish with as high of a gloss as you want, or use eggshell great paint.
You can easily attach things to the wall.
You don’t have to worry about dents.
Bob up in Edmonton Wolf # 2 – just did a blog on his new shop he used OSB, and painted the walls white, now you need sunglasses in the shop.
-- Ed Collinge- Edmonds, WA.
Bookmark And Share This Page
