RUN CAPACITOR
Forum topic by JAYELSEA posted 04-24-2012 11:36 PM 1170 views 0 times favorited 5 replies Add to Favorites Watch
View JAYELSEA's profile
JAYELSEA
3 posts in 2460 days
04-24-2012 11:36 PM
ANYONE KNOW WHERE I CAN GET A RUN CAPACITOR FOR RIGID TS 3650?
5 replies so far
View Howie's profile
Howie
2656 posts in 3160 days
#1 posted 04-24-2012 11:46 PM
Try googling Ridgid repairs shops in your area.
If you can’t find one try Allen’s Electric in Riverview Florida.
-- Life is good.
View knothead's profile
knothead
163 posts in 4185 days
#2 posted 04-24-2012 11:54 PM
If you can determine the stats on the motor graingers would surely have them but they are a little spendy sometimes, usually after you do enough research to get the correct part number they care pretty easy to find. I have even had good luck by typing the part number in a google window. you will sometimes have to sift thru alot of pages to find the one you want but it works for nearly everything I have ever set out to find.
-- So Much Wood - So Little Time! --
View knotscott's profile
knotscott
8178 posts in 3613 days
#3 posted 04-25-2012 01:13 AM
The caps don’t have to be an identical match in capacitance values….just close (+/- 20% is fine), and they have to fit the physical space available. The voltage ratings have to at least as high as the original. Just about any electrical supplier that sells capacitors should be able to help you, and they generally don’t cost a lot.
Motor caps
View Loren's profile
10477 posts in 3885 days
#4 posted 04-25-2012 03:10 AM
If you take it to a local motor shop they will test it for you
and sell you a new one. You won’t get a bargain price,
but you’ll get one that works for your motor.
View waho6o9's profile
waho6o9
8539 posts in 2814 days
#5 posted 04-25-2012 03:57 AM
http://www.ereplacementparts.com
Here ya go. They seem to get the hard to replace parts. Good luck.
