Moving Logs
Forum topic by Milo posted 04-24-2012 08:16 PM 4772 views 1 time favorited 18 replies Add to Favorites Watch
View Milo's profile
Milo
869 posts in 3283 days
04-24-2012 08:16 PM
This might sound crazy, but I need advice on moving logs!
My coworker wants a large cherry tree removed from her yard, and I want the tree! I found a mill that will cut it for me, and I’m happy to let it dry on it own.
But the thing is between 18 and 24 inches in diameter! How the heck would I move that??
I’m THINKING of renting a large truck and hoping she hires someone with a lifter of some type to put the logs in the truck. The mill has a fork lift.
Any other ideas if the tree service are bums and only drop the tree?
THANKS!
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
18 replies so far
View chrisstef's profile
chrisstef
17305 posts in 2970 days
#1 posted 04-24-2012 08:21 PM
How about a truck with a boom arm on it?
View mtenterprises's profile
mtenterprises
933 posts in 2657 days
#2 posted 04-24-2012 08:32 PM
A tripod and a come-along to lift one end to pickup truck bed hight set that end down on the bed then lift the other end and back under it.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Mike's profile
Mike
66 posts in 2346 days
#3 posted 04-24-2012 08:33 PM
Depending on the lenth of it (or how you cut it) you can rent a skid steer with forks on it to load it on a car trailer not many places rent a flat bed truck
-- But hon I need this tool.......
View Milo's profile
Milo
#4 posted 04-24-2012 08:33 PM
Are those things you can rent? Any idea how much it would cost? I’m totally stupid here, so be patient. ;)
chrisstef
#5 posted 04-24-2012 08:41 PM
a bobcat would run you about $275. Id try calling a tow truck company, their winch would certainly handle a log like that.
View towtruckmafia's profile
towtruckmafia
7 posts in 2488 days
#6 posted 04-24-2012 09:09 PM
Yeah the tow company is a good idea, with a rollback flatbed. They get weird calls like that, cause I’ve done them.
View Nomad62's profile
Nomad62
726 posts in 2922 days
#7 posted 04-24-2012 09:10 PM
Cherry trees are the heaviest I have moved yet; they will be heavy like you won’t believe. But before you worry that, make sure the tree service will cut it down as a log! I have found that if nothing is pointed out clearly they will hack it down in firewood lengths every time. Spray paint lines where you want it cut, making it obvious. As far as moving it goes, a 10 foot length will weigh about a ton, so plan on a boom truck or trailer with a winch that will safely do it. You can indeed rent them, boom trucks are spendy, trailers not too bad. You can attach a come-along to the front of a decent trailer and pull the log up a ramp, lots of work but it does work. Best of luck!
View crank49's profile
crank49
4030 posts in 2935 days
#8 posted 04-24-2012 09:20 PM
I’d vote for the wrecker service with a rollback flatbed.
I had one locally move my safe, 2000lbs, from one store location to another.
They move stuff like this all the time.
Charged me the same as towing a car; about $75.
This would be way cheaper than a boom truck crane and a flatbed.
An equipment mover would have the crane and truck, but would cost at least $250.
And like Nomad said, be sure they don’t hack it into firewood. They normally try to chop things up into pieces small enough for a couple of people, or a skid steer, to handle.
On the other hand, if they leave it big, you are liable for getting it moved so have a plan B. A backup mover, or a chainsaw.
View HalDougherty's profile
HalDougherty
1820 posts in 3201 days
#9 posted 04-24-2012 09:53 PM
Check these links. You’ll see how to load your logs onto a trailer with very little equipment.
http://lumberjocks.com/mart/blog/7919
http://www.forestryforum.com/board/index.php?topic=39236.0
Search google for “parbuckling logs” and you’ll find a lot of information. here’s a diagram showing how you load them. All you need is a trailer, some rope and a winch of some kind. I’ve used both electric and hand winches.
-- Hal, Tennessee http://www.first285.com
View derosa's profile
derosa
1572 posts in 2799 days
#10 posted 04-24-2012 11:42 PM
If I had to do it I’d bring a drill, a big bolt with an eyelet on one end and an engine hoist. and use an engine hoist to lift up one end that I could then back the trailer under, most have a 2k lb weight limit but if you’re only lifting one end you won’t exceed that. Just make sure the bolt is strong enough and long enough to really bite in. For an 8’ long you should easily be able to get about 5’ of the log on the trailer then a cheap come along will pull it on the rest of the way. Harder part might be getting it off the trailer when you get to the mill if your trailer has sides.
-- --Rev. Russ in NY-- A posse ad esse
View Doss's profile
Doss
779 posts in 2228 days
#11 posted 04-25-2012 03:42 AM
Boy oh boy do I have experience doing this! If the tree service can do it, let them. At least let them haul away the small limbs. You’re probably not going to want to put that in the back of a truck unless you cut it down to 10’ lengths… then it’s going to be a pain to get out without possibly damaging the truck (from what I can tell you’re going to be renting one). Trailer is the way to go. Make sure it can handle at least 3000 lbs. Get the tree service to load it if possible. This will save you a lot of headaches and logistics work.
Big logs need power equipment (skid steers, tractors, and such) to move without risking potentially damaging something (yes, you can move it without equipment, but the potential for damaging something increases). We had a rock lift that could pick up boulders… we almost destroyed it lifting an oak log.
If you want to risk it though, here’s something to try if HalDougherty’s method doesn’t work (I have seen people use that method to pull logs onto trailer and small log trucks). Also, I take absolutely no responsibility for what happens :
First, get a trailer.
Then, lift the small end of the log up high enough to get into the trailer. If the trailer does not have a smooth bottom, lay some plywood or something similar down.
Back the trailer under the small end.
Remove whatever you were using to lift the small end up once the small end is on the trailer.
Anchor the large end down.
Back up the trailer… essentially sliding it under the log.
This may work… I’m not sure. I just figured out really quick that for the logs I move that I need power equipment. Two logs lifted for me were approximately 8,000-10,000 each! Good luck!
-- "Well, at least we can still use it as firewood... maybe." - Doss
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2232 days
#12 posted 04-25-2012 06:03 AM
Best situation for you is rent a flatbed with a lift gate.Bring a couple friends and manhandle those logs onto the truck peavey crowbars what ever you got..That is a small diameter not hard to move easy one man.
Anything near 8kplus will need a boom truck excavator or crane.THis is a 25’ 40” diameter weighed in at 12k pounds.
View RussellAP's profile
RussellAP
3103 posts in 2250 days
#13 posted 04-25-2012 02:05 PM
A tree service will pick them up and haul them where ever you want.
View Milo's profile
Milo
#14 posted 04-25-2012 03:20 PM
I’m hoping to get the tree service to move them now! My friend are really up on what I want to do, so HOPEFULLY the tree service won’t screw up. Spray paint is a good idea…
Wrecker service #2 (I do know a guy…)
Joseph! Whoa! That’s a tree! How many board feet did you get out of that?
View dhazelton's profile
dhazelton
2754 posts in 2260 days
#15 posted 04-25-2012 03:45 PM
Well, a dual axle trailer with a winch is best, so you’d have to rent that, AND the truck to tow it, AND buy chains or tie downs, AND risk hurting yourself. I agree with letting the tree service haul it there for you. Will probably cost less in the long run.
