Span limits of 1 1/4" mdf
Forum topic by xylophage posted 04-23-2012 10:33 PM 1445 views 0 times favorited 3 replies Add to Favorites Watch
View xylophage's profile
xylophage
70 posts in 2558 days
04-23-2012 10:33 PM
Topic tags/keywords: veneering question
I am building a desk top that is made up of 1 1/4” mdf. That will be veneered with 1/16” of an inch quilted maple, on both sides. It will have a boarder of 3” wide 1 3/8” thick bubinga. It will be supported by legs on the four corners and the aprons in between the legs.
The over all demotions of the mdf center will be 20” deep and 54” wide. With the bubinga boarder it will be 26” deep and 60” wide.
I was wondering if there is any danger that the top could sag or warp, in anyway?
Any input would be great. I searched for span limits of 1 1/4 mdf but could only find limits for 1/2”,5/8”, and 3/4”.
Personaly, I believe the boarder of bubinga will add a lot of strength?
-- D.A Winograsky
3 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2874 days
#1 posted 04-24-2012 04:33 AM
Are there pedestals, or just legs and an apron?
What you’ve got going here is a chance to get the strength you need from the apron stock.
Given that, I don’t see the advantage of going to a top that thick. It will weigh something around 35 lbs, just the core piece. I’m guesstimating the bubinga will more that double that.
Putting that much mass on four legs might be an interesting journey.
Does the top have to be consistent thickness all the way through?
Kindly,
View Loren's profile
10476 posts in 3672 days
#2 posted 04-24-2012 04:39 AM
With aprons you’ll be fine.
View davidroberts's profile
davidroberts
1027 posts in 3510 days
#3 posted 04-24-2012 04:54 AM
Like Loren said aprons will add a lot of strength all the way around. If you are still concerned, you could add a cross member from front to back. Even a one inch hardwood cross member would add some support. This next option may not be to your liking but a 3/4 or even 1/2 inch square tube cross member tucked away in slots in the aprons would sure firm it up.
-- Better woodworking through old hand tools.
