corrosion stopper
Forum topic by jimmy J posted 04-23-2012 03:30 PM 1415 views 0 times favorited 4 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2375 days
04-23-2012 03:30 PM
I need to add some corrosion blocker on my new TS. CSP / Blaster (as in photo attached) is all i could find at my big box. does this stuff work? – seemed expensive. alternatives (without mail ordering something)?
View jeff robinson's profile
jeff robinson
115 posts in 3723 days
#1 posted 04-29-2012 01:40 PM
i just use Johnson floor wax on my ts after cleaning off the grease they put on to protect at factory i use it on my ts ,bs, dp,and scroll saw
-- jeff robinson, panama city, fl
View Howie's profile
Howie
2656 posts in 2919 days
#2 posted 04-29-2012 02:26 PM
If you have a Bass ProShops near, try G-96 gun spray(by Outers). Been using it for years and won’t have any effect on the wood.
-- Life is good.
View PutnamEco's profile
PutnamEco
155 posts in 3282 days
#3 posted 04-29-2012 03:49 PM
Some corrosion inhibitors react with wood finishes. You may want to see if this product does. Fish eyes suck. It would appear that the Blaster product is petrolatum based product which may or may not give you problems. B’lasters Dry Lube is a great product, I use often for lubricating my tools mechanisms, as it does a good job of lubricating while not allowing sawdust to adhere. It does however lead to finishing problems if it gets onto wood.
When I know I will not be using a tool for a while I like to spray it down with Boeshield T9 and NOT wipe it down until I use the tool again, If it is a tool in use, I’ll just use wax. A lot of corrosion preventives end up being rather costly if used often. A tin of Johnsons wax is good for many applications and can be had for just a few dollars.
-- “The test of our progress is not whether we add more to the abundance of those who have much; it is whether we provide enough for those who have too little.” ― Franklin D. Roosevelt
View Sanity's profile
Sanity
174 posts in 2686 days
#4 posted 04-29-2012 04:03 PM
I have no experience with the Blaster product. I personally use Boeshield T-9 and have found this to be very good for keeping my cast iron surface rust free. If a tool is not going to be in use for a while, I typically give it a heay coat. The T-9 is pretty expensive though.
-- Stuart
