Riving Knife Alignment; Grizzly G0715P Question
Forum topic by david_larch posted 04-23-2012 02:41 AM 3544 views 0 times favorited 13 replies Add to Favorites Watch
View david_larch's profile
david_larch
102 posts in 2389 days
04-23-2012 02:41 AM
Hi all,
While cutting the plywood today for my bathroom vanity I encountered a problem with my riving knife. I have a Grizzly G0715P with a Forrest WW2 thin kerf blade. I remember seeing others on here had the same combo. I just got my saw and set it up a week ago. When pushing wider stock through I would hit the riving knife every time and stop immediately. I tried a few different pieces, checked the blade and fence parallelism with a dial, laid a straight edge to the blade and knife for alignment, and tried adjusting the riving knife several times. The knife doesn’t seem to want to go all the way to the ‘left’ on the rear of the base. Even with that in mind, my first thought is user error. Anyone every encounter this? Anyone else with this saw have a tip?
I ended up taking it out for the rest of the afternoon, but that isn’t my favorite thing to do.
-- www.alibiwoodworks.com
13 replies so far
View DannyB's profile
DannyB
46 posts in 3508 days
#1 posted 04-23-2012 02:55 AM
You said you laid a straight edge to it.
Is it in the center of the blade?
Note that not every thickness riving knife will work with every thickness blade.
Generally, the knife has to be thicker than the plate body, and thinner than the kerf.
The kerf “thickness” specs on most of these blades is usually rounded up or down (IE some will claim 3/32, which is 0.09375, when it’s really 0.100).
I believe the forrest WWII thin kerf is 0.100. According to the grizzly specs, the G0715p riving knife thickness is 0.100. It also says:
Required Blade Body Thickness…...................................................................... 0.071 – 0.094 in. (1.8-2.4mm)
Required Blade Kerf Thickness…........................................................................ 0.102 – 0.126 in. (2.6-3.2mm)
At least to me, this would imply to me that it would not work with a 0.100 thickness blade like the WWII thin kerf.
david_larch
#2 posted 04-23-2012 08:30 PM
Bummer, maybe I will install the factory blade to see if it is an alignment issue. Hate to set a side a great blade.
DannyB
#3 posted 04-23-2012 08:34 PM
You could ask grizzly if they make a thinner riving knife for this purpose.
View knotscott's profile
knotscott
8103 posts in 3462 days
#4 posted 04-23-2012 08:39 PM
A blade width of 0.100” is a tight fit for a riving knife of 0.100”....not much wiggle room. The runout of the arbor and blade is the only clearance. You’re gonna need a wider blade or a narrower riving knife.
DannyB
#5 posted 04-23-2012 08:42 PM
And that assumes the blade machining tolerances are essentially hyper accurate.
I wouldn’t be surprised if the plate/teeth/etc were off enough to matter here (IE 0.0005)
View crashn's profile
crashn
528 posts in 2552 days
#6 posted 04-23-2012 09:28 PM
I have that same combo, and it works, just have to make sure that the riving knife is perfectly inline with the blade. Took ALOT of tinkering with the adjustments screws (they are a PAIN to adjust), but it is possible and once properly adjusted, does not bind.
-- Crashn - the only thing I make more of than sawdust is mistakes
david_larch
#7 posted 04-23-2012 09:50 PM
crashn, did you find that you had to adjust the 3 vertical screws in addition to the 2 at the bottom of the plate?
View northeaster's profile
northeaster
52 posts in 2579 days
#8 posted 04-23-2012 11:26 PM
Have you looked closely at your riving knife? Etched on mine (delivered 3/2011) are the following:
Thickness: 0.086”
Blade diameter: 10”
Blade body: 0.063-0.079”
Blade kerf: 0.094-0.118”
These numbers are also consistent with those from the G0715P manual I downloaded a few months ago.
I initially found it a bit difficult, too, to line up the riving knife properly. But loosening all the screws you mention and setting it parallel with the blade 1” above the table made things right with my default blade (Infinity 010-060, specified kerf 0.104”).
david_larch
#9 posted 04-23-2012 11:47 PM
I’ll check tonight, likely the same as yours. I have the WWII 3/32 kerf (.09375) I emailed Forrest to see all the specs and ask if the 1/8” kerf might fit the tolerances. I’m going to give it another shot in a few days on the alignment end, too. it is pretty hard to align for this novice.
DannyB
#10 posted 04-24-2012 12:26 AM
Interesting, sounds like they changed the riving knife, the numbers I originally quoted are from the grizzly spec page (I don’t have a G0715P) that i downloaded yesterday.
However, I do have a WWII thin kerf. I measured it with dial calipers, and it’s definitely 0.100, which is consistent with what the forrest specs actually say. They call it 3/32 because it’s convenient.
The only real 3/32 blade i know of is the ridge carbide ts2000
crashn
#11 posted 04-24-2012 12:58 AM
I end up messing with all the adjustment screws, and I dont have allen wrenches long enough to fit all the way down in there. It is quite a pain in the tuckus, about the only negative I can say about the saw.
View gfadvm's profile
gfadvm
14940 posts in 2776 days
#12 posted 04-24-2012 01:49 AM
I have that same saw and removed the riving knife a few days after I set it up. I’m careful to wedge any cut that wants to close and haven’t missed the riving knife yet.
northeaster
#13 posted 04-24-2012 03:25 AM
I agree, crash: getting to the lower bolts could be frustrating without 3/8” drive metric Allen sockets and an extension. With them, I think it’s not too bad.
