Jointer knives
Forum topic by Iggles88 posted 04-23-2012 02:02 AM 4378 views 0 times favorited 8 replies Add to Favorites Watch
View Iggles88's profile
Iggles88
247 posts in 2264 days
04-23-2012 02:02 AM
I have a pretty new jet 6” jointer. Only like 4 months but I made the mistake of not moving my fence when edge jointing and dulled my blades much sooner then I should have. Point being I need to get a backup set while waiting for my blades to be sharpened. I want to buy the Freud blades but I read a review about them not fitting. Every set of knives I’ve looked at are 1/8” thick. Not understanding why the Freud blades wouldn’t fit I measured my blades and they’re only a 1/16 thick so where can I find a set of blades to fit the jet jj6csx jointer. I know jet makes a replacement set but they are 85 dollars and have gotten terrible reviews. I really need to get my jointer back up and running so any advice would be great. Thanks in advance.
8 replies so far
View Dusty56's profile
Dusty56
11819 posts in 3592 days
#1 posted 04-23-2012 02:54 AM
http://globaltooling.bizhosting.com/products/knives-planer/t1-hss-planer-knife-sets.html
View gillyd's profile
gillyd
136 posts in 2550 days
#2 posted 04-23-2012 11:49 AM
Aren’t those blades double sided? If they are in the meantime you can flip them around while you find a backup set.
View jmos's profile
jmos
820 posts in 2273 days
#3 posted 04-23-2012 12:45 PM
Yes, your knives are two sided, you can flip them.
I’ve heard good things about the global knives.
One question, are your knives the quick set type? If they are, that’s a different animal than the plain (non-quick set) knives and are not interchangeable.
-- John
View Chris 's profile
Chris
1879 posts in 3895 days
#4 posted 04-23-2012 01:15 PM
What makes them “Quick Change” versus the normal blades?
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View syenefarmer's profile
syenefarmer
483 posts in 2984 days
#5 posted 04-23-2012 03:30 PM
Are you certain that your jointer takes 1/16” thick knives? I also own the Jet JJ-6CSX and according to my Owners Manual the knife size is 6-1/16”x5/8”x1/8”T. I get my replacement knives from Holbren, their Model #STB4625125. Although they are 1/16” shorter than the OEM knives they work and are a fraction of the cost of Jet knives and the quality is first rate.
View bobdurnell's profile
bobdurnell
315 posts in 3801 days
#6 posted 04-23-2012 03:37 PM
Iggles88—I have the exact same jointer and the cutter head will accept any 6inch knife, and they are 1/8inch in thickness. Unless your model is a special one I see no reason why you can’t use regular jointer knives. My second set of knives if from Infinity. I regularly move my fence to use all of the knife and when I get a coupla inches from the outside edge I have them sharpend and replace them with the back up set using the maga set jig. Good luck. bob
-- bobdurnell, Santa Ana California.
View jmos's profile
jmos
#7 posted 04-23-2012 03:43 PM
The quick set knives (for the CSDX model) has a cutout in the knife where a cam rides. You can turn the cam to adjust the height of the knife, in theory making them quicker to set. I don’t know if they help versus a regular knives, they are still a PITA to set, but maybe less than others.
http://www.tools-plus.com/powermatic-708801dx.html
The quick set knives are lot harder to find, and more expensive, and you can’t use the regular knives in their place, which is why I asked, just to save a potential problem.
-- John
Iggles88
#8 posted 04-23-2012 08:10 PM
My knives aren’t double sided, I assumed they were but that’s only for the quick set knives. I took mine out thinking I’d just turn them around but found they were only single sided causing me to need to get a second set. I figured the 1/8” knives could be used but when I seen that review that they didn’t fit I had to ask. I ordered Freud 6 1/8 3/4 1/8
