Making A Wooden Soccer Ball
Forum topic by Dustmite97 posted 04-22-2012 05:07 PM 6071 views 0 times favorited 3 replies Add to Favorites Watch
View Dustmite97's profile
Dustmite97
439 posts in 3214 days
04-22-2012 05:07 PM
Topic tags/keywords: question resource lathe joining turning shaping
Hey everyone! I have seen some soccer balls here and I am just blown away by them. I decided that I’m going to go for it and give one a try. I am wondering in any of you know any good sources of information on them. I mainly need to know what the angles are and other little tips and tricks as well.
3 replies so far
Dustmite97
#1 posted 04-22-2012 06:02 PM
Thanks Jonathan, very good information.
View Col Baker's profile
Col Baker
17 posts in 2189 days
#2 posted 05-22-2012 11:01 AM
Hi Dustmite97 – I have made several soccer balls after much calculations and cad layout – the angled edges of the pieces need to be 16.407 degrees for the Pentagons and 20.921 degrees for the Hexagons. These angles work well and are justified by accurate Cad layout and the fitting of the pieces. The standard soccer ball of 8 1/2 inch dia (218mm) using an edge length for the both pieces of 48mm. You require 20 Hexagons and 12 Pentagons. The trick is accuracy in manufacture and assemble one piece at a time as trying to make groups of items will not fit exactly. Even if you are truly accurate, trust me, you will have to do some slight trimming as you go for accurate fitting to avoid any gaps. First one I made was a disaster but you soon learn. Machining the final ball is tricky but I have an easy solution. I can send you the a pdf copy or cad layout, photos and tips on manufacture if you like. My email address is col_draw@tpg.com.au
Good luck.
-- Col B.
View sofat's profile
sofat
1 post in 2163 days
#3 posted 06-17-2012 11:13 AM
I also am having trouble with the soccer ball . calculations by another source just do not meet after a lot of wasted timber and time can any one help please
