Green Pine how long before I can use it?
Forum topic by Sumdume posted 04-22-2012 03:27 PM 3921 views 0 times favorited 3 replies Add to Favorites Watch
View Sumdume's profile
Sumdume
78 posts in 2797 days
04-22-2012 03:27 PM
Topic tags/keywords: pine router milling question
I picked up a couple of pieces of pine (slash pine I think) yesterday. I want to use it to make some router bowls and platters. The wood was cut yesterday so there is a lot of sap oozing out.
One piece is 10-12 inches across and about 48 inches long. The other is the same diameter and only 18 inches long.
I understand that wood dries at about 1 inch per year and I do not want to wait 6 years to use the wood. Should I mill the pieces or can I work the wood green? Other than the issue with sap, what issues will I have to contend with if I work the wood green?
-- Rule # 1 - Don't mix yer blood and sawdust!
3 replies so far
View derosa's profile
derosa
1572 posts in 2799 days
#1 posted 04-22-2012 07:10 PM
This post just down from yours explains a lot regarding drying time http://lumberjocks.com/topics/37192
Major thing is just seal the ends to prevent cracking. I used canning wax from the grocery store in a double boiler to seal the ends of mine.
-- --Rev. Russ in NY-- A posse ad esse
Sumdume
#2 posted 04-22-2012 08:31 PM
Thanks Rev. Russ. It sounds like I should mill the logs to smaller pieces so they will dry faster.
View Sawkerf's profile
Sawkerf
1730 posts in 3032 days
#3 posted 04-22-2012 09:21 PM
I’m not a turner, but I believe many of them will rough cut green wood then let it dry before finishing the piece.
