Titebond Information
Forum topic by ChuckV posted 04-21-2012 12:14 PM 4267 views 0 times favorited 9 replies Add to Favorites Watch
View ChuckV's profile
ChuckV
3083 posts in 3399 days
04-21-2012 12:14 PM
Topic tags/keywords: glue temperature
I have an unheated shop in New England. In the cold weather, I always do glue-ups in the house. I use Titebond III.
During the Spring and Fall, the temperature is often high enough to glue-up in the shop during the day, but then drops below the recommended temperature at night. In this situation, I haul the piece into the house for the night. I wondered if this is necessary. Using the form at titebond.com, I asked how long after glue-up the temperature is important.
I received an excellent response in just 30 minutes. I thought I would share this information, as well as give a big thumbs-up to the customer service.
Titebond III will not chemically perform at or below its stated Chalk temperature of 47° F. If you reduce the temperature of the wood, glue or room below the chalking temperature, the glue does not coalesce (form a continuous film) on drying. This is evidenced by a dried film which is whiter than normal and looks “chalky.” Where the bond is formed at all, the resultant strength of a chalked glue joint is lower than normal and will always remain weak and often times will fail.
In regards to timeframe, the temperature really needs to be maintained for a minimum of 24 hours after glue up. At temperatures closer to the 47° F, you may want to wait 36 hours to be sure the glue has dried completely.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
9 replies so far
View boxcarmarty's profile
boxcarmarty
15287 posts in 2231 days
#1 posted 04-21-2012 12:37 PM
Excellent info Chuck. Thanks for posting…..
-- My mind is like lighting, one brilliant flash, then its gone.....
View Jeff in Huntersville's profile
416 posts in 3066 days
#2 posted 04-21-2012 12:38 PM
Good information to know. I’m fortunate that recently, even in the middle of winter, my garage here in North Carolina never drops into the 40’s. Summer temperatures are another matter.
View robert triplett's profile
robert triplett
1566 posts in 2976 days
#3 posted 04-21-2012 03:33 PM
I had a couple of glue failures this winter when the titebond 3 went white quickly. It gets close to zero often, but not really bad this year. I had to increase the temp in my shop and cut back on making big cutting boards. I started to ‘whack’ the boards on my work bench to get some idea if the glue bond was good! thanks for the info.
-- Robert, so much inspiration here, and now time to work!!!
View LukieB's profile
LukieB
966 posts in 2201 days
#4 posted 04-21-2012 05:55 PM
Wow, unfortunately I know exactly what they mean by “chalky” white film….hope those joints don’t fail. Oh well, too late to do anything about it now.
-- Lucas, "Someday woodworks will be my real job, until then, there's this http://www.melbrownfarmsupply.com"
View smokey1945's profile
smokey1945
75 posts in 3254 days
#5 posted 04-21-2012 10:35 PM
+1 for covering with an electric blanket!
-- TheShadeTreeWW If God wanted me to touch my toes, he'd have put them on my knees
View derosa's profile
derosa
1572 posts in 2707 days
#6 posted 04-21-2012 10:47 PM
That explains why the last two boards I glued onto my workbench came off so easily when I didn’t think they glued on correctly. Only took a small chisel and a hammer to seperate them and they came apart at the glue line. All my other projects I glued in the cold but immediately set in the hallway outside my shop door and they bonded strong.
-- --Rev. Russ in NY-- A posse ad esse
View Loren's profile
9763 posts in 3519 days
#7 posted 04-21-2012 11:17 PM
I would recommend you look at using urea glue for winter
glue-ups.
PVA glues are convenient and I use them, but faced with
the threat of joint failure and shuffling work into the house
you are dealing with in the winter I would mostly use
something else. Weldwood, sold in a powder, has
a very long shelf life and is versatile.
View Martyroc's profile
Martyroc
2712 posts in 2177 days
#8 posted 04-21-2012 11:34 PM
Thanks for posting the info, I knew the cold weather was a factor, I have not had any joints fail so far, (fingers crossed), but there is always a first time. Up here in the north east you never know what winter is going to be, last year was like antartica this year, one snow in October, ( go figure) and 50-70 degrees on and off through Jan- March. I have a heated shop but the cost to heat it up here, I might have to sell a Kidney which only gets me through one winter, LOL.
-- Martin ....always count the number of fingers you have before, and after using the saw.
View Dave's profile
Dave
11426 posts in 2711 days
#9 posted 04-22-2012 04:31 PM
Good stuff Chuck, thanks
