| Forum topic by dask | posted 396 days ago | 1271 views | 5 times favorited | 10 replies | ![]() |
396 days ago |
Topic tags/keywords: mobile base hercu lift table lift Thought I would give it a try and see how well this operates…was built in a hurry because the heat in Phoenix hit 100 degrees today, and if you’ve ever tried to handle metal tools in this heat you’ll know what I’m talking about. It works better than I expected. |
10 replies so far
#1 posted 396 days ago |
It’s better if you embed the video.. Have a great day! |
#2 posted 396 days ago |
Nice, really nice. -- I'll be a woodworker when I grow up. HHHOPKS |
#3 posted 395 days ago |
HHHOPKS, I will take some pics, and add wording in Photoshop today to the pics. Thanks |
#4 posted 395 days ago |
Wow…nice contraption, dask! |
#5 posted 395 days ago |
Thanks Andy, |
#6 posted 395 days ago |
I like it, I know what I’m going to be working on tomorow. Thanks for posting it. |
#7 posted 395 days ago |
John, throw some pics here so we can see your project. |
#8 posted 395 days ago |
dask i like this too.i bought the last mobile cart on sale it was 40 bucks and really not that good i’m going to make some of these for the rest. thanks for sharing and the link too -- Jesus Is Alright with me |
#9 posted 395 days ago |
Ok, lets try this… 1. First of, you will need to cut two 2×4’s for the support rails. Do not attach the hinges yet, just get the support rails to fit where and how you want them to. 2. Once you are have your support rails cut, then size and cut your swivel rail, make the swivel rails as long as possible since your casters are attached on the ends. Wider stance=more stability. Now, attach the hinges. Leave some space between the support rail and swivel rail when you attach the hinges so the casters underneath do not come in contact with the support rail when the wheel is rotating…1/2”-3/4” should be ample. 3. Now, attach your caster on the swivel rail...make sure they are centered properly or when you try to lower the swivel rail one caster might touch the ground before the other, hence putting too much pressure on only one caster. 4. Now, attach support rail/swivel rail combo to your tool. (Actually, after #5 process is done and attached then install that section to your tool.) 5. Next cut the swivel block to fit between the hinges…mine was around 6”. I cut a small recess with a Fostner bit so the head of my bolt and a washer would be flush with the block. Then I drilled a hole in the swivel block and the top rail and ran a bolt through it. Do not over tighten as you want it to move freely. Add thread lock or do like me and just place two nuts together and tighten them against each other. 6.Attach the swivel block and top rail to the hinge rail. 7. To get the proper dimension of the bottom rail is simple. While the tool is resting on its support legs the swivel rail with the casters is resting on the ground freely. Take a 2×4 and extend it far enough under the top rail to where is touching…that will be the length of the bottom rail. Once attached and you apply downward pressure on the top rail, immediately to bottom rail will move also. Adjust as needed of course, and I also used a 3/4 round router bit to cut the top of the bottom rail for a smoother glide. 8. As for the locking mechanism, I just used an old saw wrench and cut a groove for the 2×4. Please, post pics of your project so we may all benefit from improvisations done to this mobile lift. Thanks & Enjoy Dask |
#10 posted 360 days ago |
Dask, this is a great solution! I have a Drum sander on a homemade steel base with only 2 fixed wheels. This will fix the issue. I will post pics when I make it! -- You don't have a custom made heirloom fly fishing Net? |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15781 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
