Detensioned Bandsaw Blade
Forum topic by xwingace posted 04-20-2012 08:18 PM 1215 views 0 times favorited 7 replies Add to Favorites Watch
View xwingace's profile
228 posts in 2525 days
04-20-2012 08:18 PM
Once I started my bandsaw without retensioning the blade, and though I didn’t hurt myself it was pretty spectacular!
Now whenever I detension the blade, I leave the top wheel cover open to remind me to tighten it back up before I plug it in and hit the button. The visual indicator has saved me a fair bit of grief.
Be safe everyone!
-- I'm not as good as I once was, but I'm as good once as I ever was.
7 replies so far
View ratchet's profile
1391 posts in 3723 days
#1 posted 04-20-2012 08:27 PM
I have a rubber ball tied to a string that I use to signal that tensioning is needed.
10116 posts in 3584 days
#2 posted 04-20-2012 09:40 PM
I just poke the blade sideways between the guides with my finger.
It depends on the saw and blade type but usually there is some
sort of thunk if the blade is not under tension.
View DKV's profile
3940 posts in 2441 days
#3 posted 04-20-2012 10:17 PM
Wow that brings up a great question. I use my bandsaw two or three times a week and never detension it in between uses. Should I be?
-- This is a Troll Free zone.
View Gregn's profile
1642 posts in 2920 days
#4 posted 04-21-2012 02:22 AM
Like Don, I don’t detension the blade either. Probably don’t think about it cause I use it quite a bit when in the shop. Wouldn’t be a bad practice to get into.
View gfadvm's profile
14940 posts in 2627 days
#5 posted 04-21-2012 02:31 AM
I did that once. Scared the crap out of me! I made a cardboard flap that hangs over the on/off switch that says; “tension blade”. Flap must be lifted to access the on button. I spend a lot of $ on my blades and the Timberwolf guys say detensioning them will add longevity so I always detension mine.
View BilltheDiver's profile
253 posts in 2822 days
#6 posted 04-21-2012 04:10 AM
I installed a Carter quick release tension lever on my saw, and as a side benefit, it sits parallel to the saw table when detensioned. Makes it hard not to notice the tension is off.
-- "Measure twice, cut once, count fingers"
View Bill White's profile
Bill White
4882 posts in 3897 days
#7 posted 04-21-2012 04:19 AM
Made a note card that says “loose blade”, and unplug the saw so I don’t start up.
