Where can I find a.....
Forum topic by magicman posted 399 days ago 753 views 0 times favorited 13 replies Add to Favorites Watch
View magicman's profile
magicman
164 posts in 1781 days
399 days ago
Topic tags/keywords: table saw
Where can I find a 4” table saw, new or used? I am looking for one that the blade tilts 45 degrees. Can someone help?
-- Twenty years from now you will be more disappointed by the things that you didin't do then by the ones you did. - Mark Twain
13 replies so far
View Bertha's profile
Bertha
13115 posts in 865 days
#1 posted 399 days ago
I think Proxxon makes one. Not sure of the size.
View Gene Howe's profile (online now)
Gene Howe
3199 posts in 1600 days
#2 posted 399 days ago
Here ya go…but blade is only 3 9/64”
Proxxon
Here’s another, but blade is only 3 1/4”
MicroMark
87330 posts in 1749 days
#3 posted 399 days ago
I’ve seen folks on Ljs make their own table saw using a circular saw ,i guess you could do the same with a 4” trim circular sawif the store bought table saw is to spendy. Just curious what you would want a 4”table saw?
View RandyM68's profile
RandyM68
693 posts in 490 days
#4 posted 399 days ago
Harbor Freight has a little one but it doesn’t look like much. Four inches is pretty small for a table saw.
I saw this one a few weeks ago at a thrift store for $60
I had never seen one this small that was any good, but this one might have been.
If you have time, look for a used one. If you have to have a very small saw, try searching for jeweler’s saws, you might find something.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
View dbray45's profile
dbray45
2018 posts in 948 days
#5 posted 399 days ago
These people may have what you want -
http://www.micromark.com/saws.html
-- David in Damascus, MD
View Jeff in Huntersville's profile
363 posts in 1366 days
#6 posted 399 days ago
Read the reviews carefully. Most seem to be extremely under powered or expensive. I was looking for a small one, too. I was going to use it to cut very small pieces for crafts. I ended up buying a very good fine-tooth hand saw and a Grrripper for my contractor’s saw. Really small pieces I use a sharp knife.
View gagewestern's profile
gagewestern
297 posts in 1522 days
#7 posted 399 days ago
dremel makes one
-- gagewestern
View sandhill's profile
sandhill
1979 posts in 2096 days
#8 posted 399 days ago
http://lumberjocks.com/WoodMosaics has a cool saw thats like a bicycle and it seems to have a small blade, check out his photos its there somewhere and ask him where he got it.
View roy3833's profile
roy3833
18 posts in 679 days
#9 posted 399 days ago
How fancy does it have to be? I have 1 that I bought in a garage sale—its a cast table with a small blade I will have to go to the shop and measure it but it should be arround 4” there is no fence or miter gauge but if you just want a bare bones saw let me know and i will do some measuring
Roy
magicman
#10 posted 399 days ago
Hey Roy,
I’m just keeping an eye open to see what I can find. If you could shoot me some meaurements and possibly some pictures that would be great.
I’m going to be using this saw to make small boxes. Cutting out the small side on a 10” table saw that I have scares me a little.
View Tom148's profile
Tom148
28 posts in 436 days
#11 posted 399 days ago
http://www.preac.com/table_saw.htm
You might try looking at this Preac. It is widely thought of as the best for people doing model work.
This is the best and most robust I have found.
Good luck
-- Tom
roy3833
#12 posted 399 days ago
pm sent—also this has a tilt top not a tilting blade.
View Loren's profile
4898 posts in 1820 days
#13 posted 399 days ago
If you want something really pro and accurate look
for a linotype saw or print shop saw. They don’t tilt
but some have a mechanism for holding small parts
very close to the blade. I can rip short strips to very
fine tolerances with mine.
