bookmatching veneer
Forum topic by Joey posted 522 days ago 192 views 0 times favorited 2 replies Add to Favorites Watch
View Joey's profile
Joey
259 posts in 712 days
522 days ago
I’ve been veneering for a couple of years now, but only recently started bookmatching for decorative purposes. I’ve bookmatched before, but usually on the reverse side with cheaper veneer.
I bookmatched 2 pieces of madrone burl. It turned out good except for a line showed where the 2 pieces came together. the line didn’t show up until I put on the finish. I would love a little insight on this if anyone has any, like what happened and what do I need to do differently.
-- Joey, Magee, Ms http://woodnwaresms.com
View GaryK's profile
GaryK
9536 posts in 885 days
522 days ago
The edges have to be as perfect as you can get it.
I usually clamp them between two pieces of jointed lumber and use a router with a flush trim bit to clean them up. First in between the clamps them I move the clamps and so on…
Then I use veneering tape to hold the edges tight together.
Pattern differences are something you can do nothing about.
Here is an example:
Click for details
View Joey's profile
Joey
521 days ago
i clamped them between 2 boards and then jointed them on my jointer and used veneer tape, it’s just a black line and it may be the pattern of the madrone that makes the line come out like that too.
thanks gary
