Porter Cable 220 TS Question
Forum topic by JohnGreco posted 04-20-2012 01:29 PM 1724 views 0 times favorited 9 replies Add to Favorites Watch
View JohnGreco's profile
JohnGreco
284 posts in 3048 days
04-20-2012 01:29 PM
Topic tags/keywords: question tablesaw
I hope this is the right place for a question like this :)
I have a pcb220ts. One of the reasons I chose this TS is for the sliding table wing that can be kept retracted in my tight shop space, or opened up wide when I need it. Well as luck would have it when i needed it….it wouldn’t slide open! I released the underside clamp, but the wing stays put like it’s still locked in place.
I went to Lowes to see their floor model, I can’t see anything operating differently on theirs than mine- has anybody had this happen?
Thanks.
-- John
9 replies so far
View Bill White's profile
Bill White
4928 posts in 3954 days
#1 posted 04-20-2012 02:45 PM
Is this a new saw? Does it maybe have a packaging part used to secure the slider still attached?
Just guessin’.
Bill
-- bill@magraphics.us
View knotscott's profile (online now)
knotscott
8005 posts in 3369 days
#2 posted 04-20-2012 03:10 PM
Is it possible that the release clamp isn’t releasing all the way?
JohnGreco
#3 posted 04-20-2012 04:46 PM
It’s about a year old. It used to slide no problem, but now seems ‘stuck’ and I don’t want to force something and break it.
-- John
View Howie's profile
Howie
2656 posts in 2916 days
#4 posted 04-20-2012 10:25 PM
Have you lubed it lately?
-- Life is good.
JohnGreco
#5 posted 04-20-2012 10:29 PM
That’s what sh…oh, right. Yes, lots o’ lube but no different result.
-- John
Howie
#6 posted 04-21-2012 01:54 AM
-- Life is good.
View ShipWreck's profile
ShipWreck
557 posts in 3746 days
#7 posted 04-21-2012 10:20 AM
John,
Sounds like you got a little sawdust in your slider/rail assembly. Some woods can get pretty tacky sometimes. Give it a good pull….............you wont hurt anything. You can tap it with a piece of wood also. After you break it loose, give it a little WD40 and wipe it down.
JohnGreco
#8 posted 04-21-2012 07:51 PM
Thanks, ShipWreck- I’ll give that a try.
-- John
JohnGreco
#9 posted 04-23-2012 03:22 PM
A few whacks from my 5lb sledge popped it open and all is well again :)
-- John
