DIY Jig Knobs
Forum topic by dask posted 04-20-2012 09:09 AM 19573 views 8 times favorited 11 replies Add to Favorites Watch
View dask's profile
dask
22 posts in 2230 days
04-20-2012 09:09 AM
Topic tags/keywords: knobs jigs wood knobs t track
My first post here, and Im not sure if anyone has posted something similar in the past…but here goes.
First, I trace the knob template unto a piece of wood…
I then draw 3 lines from each of the 6 points that you see on the knob to find the center point.
I then use a 1/2 fostner bit to cut out where the 1/4-20 nut will fit into.
The next step is to use a hole saw to cut out knob. By keeping your piece secured to the drill press you are guaranteed that the hole for the nut and the outer cut will line up perfectly.
I then attach a fostner bit that will have the same radius as the knob, I secure the knob and drill out each section. This part takes some time since each time you have to release how you secure the nut to the drill press so you can rotate and align for the next cut…I use hold down clamps.
From smaller stock cut out part that will attach to the opposite side.[/COLOR][/B]
I used a drum sander on my drill press to sand the knobs before I glued them…also, to make sure the holes line up. run a 1/4 bolt thru the knob and the round piece to make sure they are aligned properly when glued.
11 replies so far
View dask's profile
dask
#1 posted 04-20-2012 09:16 AM
I will search the forums guide but this might be faster…how do I get my pics to show properly? It seems that the right side of the pics are cutoff. Doesn’t it automatically autofit the pic?
View KnickKnack's profile
KnickKnack
1088 posts in 3471 days
#2 posted 04-20-2012 12:38 PM
It does seem to if you upload the picture to LumberJocks (I downloaded yours from photobucket, and uploaded it)...
PhotoBucket itself will let you resize the pictures to the “right” size, which seems to be a width of 640.
People here can “right click” and “View Image” whereupon they’ll get the full size version, but they don’t know there’s some missing, do they!
The site autoresizing would be good though.
BTW – cool and useful post!
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
View Bob817's profile
Bob817
670 posts in 2287 days
#3 posted 04-20-2012 12:51 PM
That’s alot easier than a tip I found on another web site and much nicer, thanks for posting.
-- ~ Bob ~ Newton, N.H.
View Lee Barker's profile
Lee Barker
2170 posts in 2755 days
#4 posted 04-20-2012 02:39 PM
Nice sequence. I’d make one suggestion though: If you screwed the knob down to a sacrificial board to cut the finger recesses, couldn’t you just drill one, rotate it, and drill the next?
I am looking now for excuses to make a few of these. Thanks for posting it. Have you tried this with Baltic birch ply?
Kindly,
View dask's profile
dask
#5 posted 04-20-2012 06:27 PM
Lee, im sure that would work but I prefer to rotate freely then secure to sacrificial board with a hold down clamp.
Im sure your idea is probably my faster and I guess I could secure it with a wind nut so it wouldn’t spin. I have 6to more to make in 5/16 and will try your idea.
BTW…the template is from an old fan that I disassembled and kept spare parts.
As for the ply…never made these before…youre looking at the first four but im sure ply would work.
Knick knack…thanks for the info. I also belong to routerforums and there is auto resizes…maybe they should add that option here.
Who do I need to speak to…LOL.
dask
View MrRon's profile
MrRon
4630 posts in 3148 days
#6 posted 04-22-2012 05:01 PM
Put a flat washer on the bottom so you don’t tear up the wood when tightening.
View Dusty56's profile
Dusty56
11819 posts in 3592 days
#7 posted 04-22-2012 06:07 PM
Very nice Blog ! Details AND Pictures even I could understand : ) LOL
Thank you and welcome to LJ’s !
View jusfine's profile
jusfine
2422 posts in 2830 days
#8 posted 04-22-2012 08:47 PM
Thanks for the tip!
Great first post!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Edwardnorton's profile
Edwardnorton
199 posts in 1831 days
#9 posted 11-04-2013 04:43 AM
I am always looking for new ways of doing this….thanks!
-- EdwardNorton
View David Dean's profile
David Dean
608 posts in 2803 days
#10 posted 11-04-2013 11:25 AM
I like your’s a lot batter.
View PaulDoug's profile
PaulDoug
1458 posts in 1608 days
#11 posted 11-04-2013 02:22 PM
Thanks for taking the time to post this tutorial. Looks like a fun little project and I trying to think of an excuse to make some. I think I will use a T-nut instead of a hex nut. It will provided more threads, (I think) and seems like it would be easier to insure it was in straight with the knob.
