how high up should the t-slot go on an aux fence?
Forum topic by jimmy J posted 04-20-2012 03:27 AM 1216 views 0 times favorited 4 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2347 days
04-20-2012 03:27 AM
how far above the table top should i put the t-slot? will be used for featherboards, clamps, etc.
View RandyM68's profile
RandyM68
693 posts in 2286 days
#1 posted 04-20-2012 03:36 AM
I would think that about half way up would be the most stable. It depends on the height of your fence and the length of the feather boards.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
View DIYaholic's profile
DIYaholic
19597 posts in 2643 days
#2 posted 04-21-2012 03:49 AM
How thick are the boards, that you work most with??? That should direct you towards an answer.
View Bobmedic's profile
Bobmedic
379 posts in 2770 days
#3 posted 05-13-2012 04:51 AM
Mine are about 2 ¾ inches but as others have said it depends on the feather boards you are using.
View KenBee's profile
KenBee
109 posts in 2603 days
#4 posted 05-25-2012 07:08 PM
The slot on my router table fence is a little over 4 inches from the table but my feather boards are adjustable as I would think all feather boards are to compensate for the thickness of the part being routed. So then if you are installing a T-Track in your fence the important thing would be to make sure it is positioned to allow the feather board to be adjusted. I just looked and the bolt to lock the feather board in place sets about the middle of the feather board slot when flush with the table top. Another thing to consider is, if you need a stop block build your own from a piece of scrap wood and two 1/4-20 hex head or T-Track bolts with wing nuts to lock it in place. Paying 20-30 dollars for a pretty aluminum or whatever stop block is insane when 1 or 2 can be made that work just as well for 2 dollars or less.
-- If it won't fit get a BIGGER hammer.
