purchased a new mk2 honing guide roller
« back to Hand Tools forum
Forum topic by joez posted 04-20-2012 12:15 AM 1626 views 0 times favorited 10 replies Add to Favorites Watch
View joez's profile
joez
120 posts in 3024 days
04-20-2012 12:15 AM
Topic tags/keywords: veritas concave
So I purchased a new roller for my veritas honing guide mark2. I thought maybe my roller needed to be changed thinking that was the problem. But I found out my blade looked like this, and for every blade I used to hone.
Does anybody know what maybe happening.
10 replies so far
View Bob Downing's profile
Bob Downing
43 posts in 2947 days
#1 posted 04-20-2012 01:31 AM
What type of surface are you honing your blades on? The only thing I can think is that it is not flat. Just the type of surface I need for honing my concave spokeshave blade.
-- BobD Chandler, AZ
View joez's profile
joez
#2 posted 04-20-2012 02:06 AM
the blade is a little exaggerated, but there is small concave. Anything from from waterstones to flat granite and sandpaper!
View JJohnston's profile
JJohnston
1622 posts in 3413 days
#3 posted 04-20-2012 02:08 AM
Are you pressing down with your fingers right in the middle as you hone?
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View DKV's profile
DKV
3940 posts in 2625 days
#4 posted 04-20-2012 02:15 AM
When I first started using mine about 3 years ago I found that I could skew the blade edge by putting too much pressure on the left or right side. I use two fingers to try and get even pressure across the blade.
Don
-- This is a Troll Free zone.
View joez's profile
joez
#5 posted 04-20-2012 03:32 AM
I put pressure on both left and right not middle.
Also is absolute must to put a camber on blade to do face grain surface grain work?
View ShipWreck's profile
ShipWreck
557 posts in 3874 days
#6 posted 04-20-2012 10:34 AM
joez? What type of paper are you using? Are you gluing the paper down absolutely flat? Most people usually come up with the opposite results of yours when not using the MK II correctly.
The only thing that come to mind for me….... is that you have a ton of pressure on the center of the blade, or your sanding medium is bulging in front of the blade as you make a pass.
Some of the more experienced guys might be have the answer. I wish I could help.
View funchuck's profile
funchuck
119 posts in 3179 days
#7 posted 04-20-2012 11:51 AM
What type of blade are you using? Since you said you’re putting pressure on the left and right sides, if it’s a thin blade (ie. from a Stanley plane), then could it be possible that it is being bent? Maybe there is dust or dirt in the middle of where the guide clamps onto the blade, thus bending the middle.
Usually, when I use my mk2 guide, I only put pressure in the middle if I am going for a straight blade (only my block plane has a straight blade, the rest have some degree of camber).
-- Charles from California
View joez's profile
joez
#8 posted 04-20-2012 01:56 PM
Does anybody know if it absolute to camber the blade in order to plane face grain?
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3237 days
#9 posted 04-20-2012 03:49 PM
no it isn´t I work with straight blades …. though I have round the corner slightly on
my smoothplanes
its only on the scrubplane I have heavy camber
I had the same isue on the first blade I sharpened when using (at that time new stones)
waterstones so I had to reflaten four of them …. since then no problem like this
I use Veritas MKII Jiig as well
if the back on the blade is hollow you will see this too
youn can use all the jiigs you want … but if your surface and the back on the blade ain´t flat …........... well
good luck with the next sharpening session :-)
Dennis
ShipWreck
#10 posted 04-22-2012 12:38 PM
Dennis…..... good call.
