| Forum topic by noone | posted 397 days ago | 1543 views | 0 times favorited | 16 replies | ![]() |
397 days ago |
2” brass wood screws to fasten cabinets and bookcases to walls? |
16 replies so far
#1 posted 397 days ago |
2 1/2 inch #8 lag screws. -- Chuck, Washington D.C. |
#2 posted 397 days ago |
I don’t know that I’d use brass screws for anything that bears weight. I’d agree with Chuck. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#3 posted 397 days ago |
Depends on the wall and what’s behind it. Definitley not brass though. -- Don't rollerskate in a buffalo herd |
#4 posted 397 days ago |
Not to be a smartass, but I would use a cabinet screw... If they are heavier cabinets, or you want to go overkill, lag screws into studs. -- "I suggest a new strategy, R2: let the Wookiee win." |
#5 posted 397 days ago |
Agree with Nick85, a cabinet screw is the way to go. I’ve installed several kitchens over the years and they are all still hanging without any problem. The extra length going into a stud gives a good solid feel to it. BTW have done the same for quite a few book 8’ bookcases with the same results. -- • "I have noticed that nothing I have never said ever did me any harm."....... Calvin Coolidge |
#6 posted 397 days ago |
I think nick85 is correct. I was looking at my kitchen cabinets which were installed 25 years ago by the home builder and they just used sheet rock screws and they seem to be holding fine, but not sure that thats a good option. I always thought that sheet rock screws didnt have a very high shear strengh rating. -- Wayne - Plymouth MN |
#7 posted 397 days ago |
Cabinet screws are the only ones I’ll use…..... -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#8 posted 397 days ago |
Cab. screws with square drive. -- bill@magraphics.us |
#9 posted 397 days ago |
I usually use 2.5” or 3” deck screws with the square drive. I use red for dark cabs and the tan screws for light cabs. I don’t worry about the color since they’re always hidden when the cabs are filled. -- Adversity doesn't build character...................it reveals it. |
#10 posted 397 days ago |
Two and a quarter inch screws, unless it’s 5/8 sheetrock. There is absolutely no need to go to lag screws. That’s just a whole lot of work. If the house is older, I wax the screws because the doug fir studs can get really hard. I have nailers in my uppers top and bottom. I can’t imagine any risk of anything shearing off, Wayne, and your 25 year history is a pretty good piece of anecdotal evidence to support that. In my leased industrial shop I have cabinets attached to the wall which is steel studs—not a recommended practice at all—and they are holding fine. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#11 posted 396 days ago |
Thanks for the replies Last night I found these around the house and used them. I didn’t want to make a separate trip out to the Depot for screws. They are 2 1/2” long and look to be #8. Deck screws? Whatever they were, they worked great! I will buy some 2 1/2” cabinet screws at Home Depot on my way home tonight.
#12 posted 396 days ago |
I think you’ll be fine with those. One thing a lot of people don’t realize is that once you screw a cabinet tightly against a wall, friction does much of the work of holding it up. -- Charlie M. "Woodworking - patience = firewood" |
#13 posted 396 days ago |
3” cabinet screws. Some cabinet manufactures send screws ie Kraftmade for one. 2 1/2” finish screws to fasten the stiles. -- You can't trust a dog to guard your food. |
#14 posted 396 days ago |
3” cabinet screws – they have a wider head on them than your standard #8 FH. I recommend square or torque drive though those are sometime hard to find at Lowes or HD. -- Shameless - Winner of two Stumpy Nubs Awards |
#15 posted 396 days ago |
I use these from Home Depot. No pre drilling, and I have never broken one off. Spax Cabinent Screws. I hold my very large clamp rack to the wall with 4 of these. -- Lee - Phoenix, AZ |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15781 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
