Powermatic Problems
Forum topic by Hamalama posted 394 days ago 516 views 0 times favorited 6 replies Add to Favorites Watch
View Hamalama's profile
Hamalama
3 posts in 1193 days
394 days ago
I have a Powermatic 66 from the early 90’s. Today I started it up and I tripped the circuit. Never happened before. However, once I fixed the breaker I tried to turn on the saw, it did not move but shimmied. I noticed that the blade and\or motor wanted to move but it wouldn’t get moving and just hummed. I checked the belts and they are fine. Do any of you have an idea on what is wrong. Hopefully the motor is fine!
View Loren's profile
4864 posts in 1813 days
#1 posted 394 days ago
Take the belts off and see if the motor will start with no load.
Likely a bad capacitor. Sometimes a motor with a capacitor on its
last legs will get going if you spin the sheave by hand. No big
deal to live with in a lathe but for a table saw no good. Capacitors
aren’t expensive.
View klassenl's profile
klassenl
98 posts in 824 days
#2 posted 394 days ago
Loren gives good advice. The other thing that may have happened is that the centrifugal switch that disengages the run windings and reconnects the start windings may have stuck in the run position.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
View Grandpa's profile
Grandpa
2380 posts in 840 days
#3 posted 394 days ago
Yes and yes on the above advice. Been there on both accounts but not the same machine.
View lieutenantdan's profile
lieutenantdan
154 posts in 471 days
#4 posted 393 days ago
Leave the Powermatic on the curb and I will be by to pick it up. Problem solved.
-- "Of all the things I have lost in life, I miss my mind the most."
View Straightbowed's profile
Straightbowed
574 posts in 463 days
#5 posted 393 days ago
not if I get there first
-- Stevo, work in tha city woodshop in the country
View Bertha's profile
Bertha
13111 posts in 858 days
#6 posted 393 days ago
^or me:)
