I have avoided building arched doors for any customers so far. A few jobs we have bought doors from other shops when arches are requested. Typically we build all of our doors. In the future it may get to a point where out sourcing our doors will be for the best but at this time we have more time then money.
So our current customer is being difficult with me and has placed me in a difficult position. The job is large and all complete except for the upper doors, which are to be arched. The customer has an 8000.00 balance with me but tells me to finish and they will pay the balance. So I find myself in a tight spot trying to get these arched doors built. I plan to purchase the frame and panel master from Woodcraft and build the doors ourselves.
Any advice on the best and most efficient process to build these arched doors.
My plan of action at this time will be to:
1. do everything as normal regarding our door process except
2. using patter, trace out arch
3. bandsaw proud of cutout
4. using panel and frame master, use pattern bit I will finish trim to exact dimension
5. Then run my panels and arched rails using starting pin and panel and frame master clamp.
Any quick and efficient suggestions anyone can add. Thanks, Jerry
-- Jerry Nettrour, San Antonio, www.topqualitycabinets.net
I can understand your concerns if you’ve never done them before, but it’s really not hard. Just go methodically and mill some extra stock in case you get blowout or other screw-up. Once you get it figured out and you have your tools and jigs at hand you’ll find you can probably do the whole run of arches in a couple of hours.
You might want to use freshly sharpened cutters to raise your panels. You’ll probably go slower when milling the curves and you may have some burning. If you want to reduce sanding do the final passes only taking off a small amount of wood.
If I were doing a lot of these I might set up 2 or 3 router tables with the same panel raising cutter at different heights. That way you can leave the jig on the part and make your cuts in succession. Of course maybe digital height gauges can substitute. If you are using shaper spindle panel raisers the cost might be prohibitive.
Jerry, While we do that on a large scale with production jigs, you should be able to pull it off. Could you send me pictures of the frame and panel master. I would love to help, but I’m not sure how to modify my method into something you can use. It sounds like you are on the right track.
Let me know how I can help. Kent
Kent, Here is the pics of the jig and templates I have:
Bryan, thanks for the web site, it looks like it is full of knowledge.
Jonathan, I am still fairly new to business. Starting on the side in 2008, then going full time in 2010. So lesson learned but I did not set forth a payment schedule in the contract. I have done that in the past with other customers. I have never had this issue with any other customer. I know I discussed with them verbally how I work the payment schedule, as I do with all of my customers. I typically request 1/2 down, then 1/2 of balance at installation and the balance after completion and punch list completed. If the customer would have done the 1/2 down and then 1/2 of balance at install, then the job would be finished right now because I would have out sourced the upper arched doors and so there would have been no delay as those would have been finished and installed a few weeks ago. With all this said, I don’t worry about the pay as I am pretty sure they are fair and honest.
Boy Jerry, I too wish you were closer. I really hope you dont buy those toys from woodcraft. I wont even begin to give linstructions for this on the computer but I am approx 5 hrs north of you. If you can get up here I ll show you the way I do it and yu can get back home the same day if your only talking 20-30 doors. Or I can ship to you pretty quickly. pm for info. if I can help you JB
I recommend 50% down. 40% on completion before it leaves your shop. Final 10% on install. Bill for storage if the customer cannot come up with the money to get the job out of your shop.
Jerry, Your jig is the same principal as mine. Mine is the $1,500 type so it is faster since it it self centering and has pneumatic clamps, but their is little difference in what it does. I’ll try to get pictures soon.
Jerry, Here are a few pictures of my jig and cutter. I know its overkill for you, but thought you might be interested. Unfortunately it costs a lot of money to be productive.
Thanks Kent for the pics. I am sure as we grow we will be able to add more pieces. I looked into the 1500.00 plus jigs but we just are not at that point financially speaking. Actually, we are getting ready to break ground soon on our 13 acres. We are going to start out by building a 60 X 40 metal shop with the future plan of adding on. Currently we lease which cost a fair amount so whenever we are able to build we will own, and hopefully save some expenses since we will not be paying a monthly lease payment. So after we build the shop, I hope to add more tools in the form of more shapers and I hope to add a CNC soon. Right now I guess it is all dreams. But the immediate need is getting these arched panel doors built, which I am sure will be fairly straight forward.
8799
224
28
61
82
1538
3556
15818
2040
496
2847
810
904
766
2742
1547
6167
