| Forum topic by Belg1960 | posted 394 days ago | 564 views | 0 times favorited | 8 replies | ![]() |
394 days ago |
Guys, I need to get a blade to cut some really small pieces of hobby sized wood. We are talking 1/8×1/8 or smaller. So I’m thinking it would have to be something with as many teeth as possible with as little rake as possible. I want to put this on my 14” Delta with a riser attached. Thanks for any thoughts. -- ***Pat*** Rookie woodworker looking for an education!!! |
8 replies so far
#1 posted 394 days ago |
http://www.orderbandsawblades.com/ -- honing my craft one mistake at a time. |
#2 posted 394 days ago |
1/8”? Many toofies and very much a turning blade. -- bill@magraphics.us |
#3 posted 394 days ago |
Razor knife, or scapel. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#4 posted 394 days ago |
scroll saw? -- Crashn - the only thing I make more of than sawdust is mistakes |
#5 posted 394 days ago |
I would cut something that small on my scroll saw with a zero clearance insert. |
#6 posted 394 days ago |
Lenox carbon steel would work great but as mentioned, it might be easier to cut the pieces on the scroll saw As far as tooth configuration, anything that will keep approx three teeth in contact with the wood but you are cutting thin stock so that “rule” will be broken. I’ve used Lenox, and the blades from Suffolk Machinery (Timberwolf) for years and either will serve you well without breaking the bank. Are you doing scrolling work on these pieces and this is why you want a 1/8 inch blade? |
#7 posted 394 days ago |
I’m with ‘crank49’ on this. Do you really need a power tool for cuts this tiny? Yep, an X-acto razor saw would be the right choice. and the piece you cut won’t end up inside the throat of your bandsaw or scrollsaw. -- Einstein: "The intuitive mind is a sacred gift, and the rational mind is a faithful servant. We have created a society that honors the servant and has forgotten the gift." I'm Poopiekat!! |
#8 posted 394 days ago |
The razor knife is the best idea. I used to build doll houses and most of my cuts were done with a scripto blade and a metal straight edge. I remember building the staircase, those were the days. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15749 |
Hand Tools
2027 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
