can oil stones be flattened?
« back to Hand Tools forum
Forum topic by Mainiac Matt posted 04-18-2012 07:19 PM 2013 views 0 times favorited 4 replies Add to Favorites Watch
View Mainiac Matt 's profile
Mainiac Matt
8562 posts in 2533 days
04-18-2012 07:19 PM
Topic tags/keywords: flatten oil stones
My bench is set up this week for sharpening and I’m going through all my planes and chisels.
This is the first time I’ve used sand paper on a granite plate and I’m pretty impressed with the results. I set up with the following grits of emery paper 220, 400, 600 and 1,000.
Does that sound about right? The 1,000 grit definately shines them up better than my Arkansas stone.
For my nicked chisels, I’m re-grinding the bevel on my India stone, then going to the Arkansas and then going to the plate for 600 grit and beyond.
When checking the stones against the plate, I can see that they are slightly cupped (~1/16” max. over an 8” stone)
Is there a way to flatten the stones? (I have access to a mill and surface grinder at work…. but don’t want to wreck my stones or the grinding wheel).
Thanks in advance for any tips.
-- I yam what I yam and that's all what I yam
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3319 days
#1 posted 04-18-2012 07:34 PM
yes you can
you can use your flat granitstone with 80 0r 100 grit to flatening here and now if you want
but there is speciel flatenigstones out thre as well
you can also use a corse Dia´montstone to flatening your stones with
the is several blogs about this here on L J and on you-tube
mustlikely you will find the infomation undersomething with Japanese waterstones
here is a link to Deiter Smidts tools site
look under sharpeningtools to find some great info too
http://www.fine-tools.com/
good luck with the project :-)
Dennis
Mainiac Matt
#2 posted 04-18-2012 08:00 PM
80 grit ont he granite plate sounds like a good option….
Especially since I just recently boke the seam on a fairly new belt on my 4×24 belt sander.
I knew that would come in handy some day…. just didn’t know how :^)
Dennisgrosen
#3 posted 04-18-2012 08:32 PM
you can also just rub two stones against each other
but in both cases be sure to check out for grits from the corse sandpaper or stone
hasn´t come on the finer stone ….. you deffently don´t want to have that experience in the mittle of a sharpening session
Dennis
View Bertha's profile
Bertha
13551 posts in 2897 days
#4 posted 04-18-2012 08:34 PM
Yes! I’ve used a coarse DMT to flatten an oilstone before.
