| Forum topic by ssnvet | posted 401 days ago | 868 views | 0 times favorited | 18 replies | ![]() |
401 days ago |
Hey guys, I have a Jet 1000 series air filter that is mounted to the ceiling of my basement shop with the supplied sheet metal mounting plates (not the eye bolts) and it is generating a harmonic of sorts, so that there’s a fairly loud pulsing noise in the room upstairs (family room). In the shop below, you hear the noise of moving air, but none of the pulsing. So I’m looking some ideas to shock mount the unit. Complicating matters is that fact that the ceiling is only 7’ 6” and I need to be able to walk beneath the filter without clocking my head. I was thinking of using something like these little rubber sandwhich mounts, as our millwork dept. at work uses them all the time for mounting small compressors in barista stands, but the application guidelines specifically say they are for compression and shear loads only. -- Matt, Pine is fine, but Oak's no joke! |
18 replies so far
#1 posted 401 days ago |
You could try rope. |
#2 posted 401 days ago |
I actually thought a thick rubber bungie cord migth be the ticket. Hoping someone else has already paved the way and solved this problem. Balancing the squirell cage fan might be another approach. -- Matt, Pine is fine, but Oak's no joke! |
#3 posted 401 days ago |
Use threaded rods and flat washer with an inch or so of rubber hose between the washers. Let it hang on the rods. You should be able to keep it as high as it is now. Double nut everything to keep the nuts jammed so they won’t come off and drop the filter on you. |
#4 posted 401 days ago |
Grandpa, how is the rubber hose on a threaded rod going to stop vibration? -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#5 posted 401 days ago |
I’ve mounted fan units on rubber bungees with great success before. Make sure it’s the heavy black rubber ones and drill and screw through the rubber at the height you need. Mike |
#6 posted 401 days ago |
TopamaxSurvivor, ssnvet, -- Tyrone - Canada, BC |
#7 posted 401 days ago |
I am wondering how Grandpa is going to rig up his hose to do it? -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#8 posted 401 days ago |
I have a JDS hung on chains. It is audible but not a vibration |
#9 posted 401 days ago |
TopamaxSurvivor, -- Tyrone - Canada, BC |
#10 posted 397 days ago |
I mounted mine on chains. Don’t have vibration issues. Strong enough rubber should work just fine, but make sure it can handle the load. Personally, I’d try chains first. Does someone make a rubber chain link? |
#11 posted 397 days ago |
You might consider hanging the air filter with springs such as; These may be overkill but if you used 4springs, each rated at at least half the weight of your filter you would never worry about spring fatigue. Your jet probably weighs 55-60 lbs. so 4 springs, rated at 30 lbs. each, would be plenty. Good luck. -- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas |
#12 posted 397 days ago |
Topamax, you mount the rods from the ceiling above. you slide the filter mounting hole up the rods and then slide the hose in place. install a flat washer and 2 nuts so you can jam them. Also jam the nuts on the top end. the filter box rests on the rubber hose and that dampens the vibration. difficult to explain on here. |
#13 posted 397 days ago |
http://www.clearvuecyclones.com/assemblysheets/CV1800MaxAssemblySheet.pdf Go to this Clear Vue site and look at page 9. Follow those pics. They show this in use. |
#14 posted 397 days ago |
Thx Grandpa. I thought it would be suppended some how. Never thought about setting it on top of the rubber hose ;-) -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#15 posted 397 days ago |
These are pretty quiet no vibration run it off the most secure place.hang and use rubber in between connections. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15809 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
