Need help finding steel or brass table pins of a specific size
Forum topic by Lee Barker posted 04-17-2012 10:15 PM 2748 views 0 times favorited 7 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 2754 days
04-17-2012 10:15 PM
The assignment: a third leaf for a dining table.
I have not been successful finding the right size pins. The existing ones are as follows, near as I could get with electronic calipers:
pin diameter .208 inches, 5.32mm
leaf hole diameter: .373 inches, 9.48 mm
The metal finish doesn’t matter, but the sizes need to be right.
If you have a Folger’s can of them, I need four sets. And you’ll forever be my hero.
Kindly,
7 replies so far
View crank49's profile
crank49
4029 posts in 2874 days
#1 posted 04-17-2012 10:54 PM
If you want steel pins you could use drill rod. It comes in very exact sizes. .208 is very close to a #7 drill bit which is .2010, or a 13/64” drill bit which is .2031.
My dining table leaves are made of oak dowels, soaked in pariffin. Would that work for your’s? Would be pretty easy to turn some, or even sand down some 1/4” dowel stock.
View Sawkerf's profile
Sawkerf
1730 posts in 2972 days
#2 posted 04-17-2012 10:56 PM
How tightly do the leaf pins need to fit? If the hole is .373”, a .25” pin should work fine. You should be able to get 1/4” stock in any hardware store.
Lee Barker
#3 posted 04-17-2012 11:38 PM
These are two-piece sets; male and female. I’ll post a pic tomorrow. Thanks for the attention to the question.
Kindly,
View Howie's profile
Howie
2656 posts in 2826 days
#4 posted 04-17-2012 11:55 PM
Sawkerf…373 is closer to 3/8(.375) .25 would be rather sloppy
-- Life is good.
Lee Barker
#5 posted 04-18-2012 03:04 PM
Here’s what a set looks like.
Sawkerf
#6 posted 04-19-2012 11:35 PM
Howie -
You’re right about 3/8”(.375) being closer to .373, but it’s bigger. Those aligninf pins in table leaves don’t need to be tight fitting. They’re mostly there to kep the leaf from sliding sideways. Once the leaves are in and the table is pushed back together, it ain’t going anywhere.
View Joe Lyddon's profile
Joe Lyddon
10032 posts in 3956 days
#7 posted 04-20-2012 12:38 AM
Don’t you think within .002 ” is close enough? ... and wouldn’t be “sloppy”...”wobbly”...? LOL
If the pin was .25 (1/4”), I can see that being sloppy from day one of the Original, fitting into a .373 or .375 hole.
Were the pins really 1/4”?
