« back to Sweating for Bucks Through Woodworking forum
| Forum topic by Adam D | posted 402 days ago | 1758 views | 0 times favorited | 28 replies | ![]() |
402 days ago |
Topic tags/keywords: titebond glue Last time I bought glue, I decided to go for the mid-grade titebond II. Is it really that much better than titebond I? Am I missing out on some great feature of titebond III? I haven’t had any joints come apart yet…anyone die-hard fans of one or the other? Is titebond original good enough? -- Adam, Rochester NY |
28 replies so far
#1 posted 402 days ago |
I use tite 3 in my cabinets not cause of the water issue cause a tight joint with finish applied is water resist anyway but i like it 15 min open time for door glue-ups but I use tite1 for everything else in my cabinets -- As Best I Can |
#2 posted 402 days ago |
I generally use TB2 for most applications but when I want a waterproof bond or a longer set up time I go to TB3. -- Bondo Gaposis |
#3 posted 402 days ago |
I used to use TBIII exclusively, mainly for the open time and lower working temp. -- He who dies with the most tools... dies with the emptiest wallet. |
#4 posted 402 days ago |
Adam, Titebond is not sold like gas. The three types Titebond I (red label) is the original, fine for any interior work or furniture. Titebond II (blue label) is Weather resistant, meaning it can get wet, like a cutting board for example. Titebond III (green label) is Water-proof, meaning it could be used for an outdoor furniture piece or anything ‘Above the waterline.’ I recommend TB III because it’s the most versatile, allows you a longer open time, and is a tad on the more liquidy side (runny) which means it spreads easier. |
#5 posted 402 days ago |
I use white glue for interior work. Common yellow |
#6 posted 402 days ago |
I like that Gorilla glue better. Ever try it? -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#7 posted 402 days ago |
crap—I used titebond 2 with some biscuits joining some pieces to make bigger stock…is it going to just disintegrate sitting outdoors this summer? I’m assuming the cedar will keep the moisture away from the glue for the most part. Maybe I’ll have to get a small bottle of TBIII before I start assembly. Russel, I use Gorilla with my mortise-and-tenon joints just because mine are never perfect and I want to fill in the gaps. No problems so far. -- Adam, Rochester NY |
#8 posted 402 days ago |
Really Loren you use white glue, like elmers glue, on interior stuff? I’m relatively new to all of this so I’m just curious as to what the reasoning is behind this instead of using wood glue. How does it hold up, how is the strength? Not trying to criticize, genuinely interested, thanks! -- Grant - S/N Dakota |
#9 posted 402 days ago |
Aren’t they all PVA; white or yellow. I thought white, as in Elmers brand, was just basic PVA glue, the same basic glue as the yellow stuff with the difference being that the yellow formula was modified to be thicker and set up faster. I normally use TB3 because I wanted the water proof feature and because it sets up a little slower, like the plain white stuff. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#10 posted 402 days ago |
I’m a big fan of III I use ot on cutting baords all the time. What a strong joint as well. -- Ken, "Everyday above ground is a good day!" |
#11 posted 402 days ago |
I was considering purchasing Titebond hyde glue. Any thoughts? |
#12 posted 401 days ago |
Titebond Hide Glue, like all hide glues can be “reversed”. Meaning it can be unglued with a little heat and moisture. This is handy sometimes, like in making violins and such, as it makes repairs feasable. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#13 posted 401 days ago |
Love TBII Dark for Walnut and Cherry. |
#14 posted 401 days ago |
I make artsy crafty items. Small cedar boxes etc. and I use white glue. For outside stuff (Like signs) I use titebond III. I like the white glue because it set up quickly, dries clear, is plenty strong and is cheap. -- In God We Trust |
#15 posted 401 days ago |
TB III here… That Hide stuff sounds interesting… haven’t used it yet… -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
