Solid Cedar Chair protection
Forum topic by Eric Criss posted 402 days ago 860 views 0 times favorited 20 replies Add to Favorites Watch
View Eric Criss's profile
Eric Criss
175 posts in 683 days
402 days ago
I’m building my 2nd NYWS adirondack chair. It is cedar with stainless steel fasteners. I’d like to protect it with a clear finish.
Some pieces have pronounced cathedral grain patterns that in some places are pealing at the peak of the cathedral. Over time I’m sure it will curl up and slice the chair’s occupant.
I’m considering hitting the entire chair with some sanding sealer (or clear shallac) to seal the cathedral grain and then protecting the chair with generic Thompsons.
Any suggestions or recommendations about this plan?
-- Eric
20 replies so far
View thedude50's profile
thedude50
3316 posts in 649 days
#1 posted 402 days ago
Actually I would go with a spar varnish it will cover and protect the wood for a better out of doors finish I used to make these chairs in sets as a kit and sold hundreds of them when times were good not so good now but they do hold up Ours were made out of rough sawn redwood 4/4 think stock they were wonderful chairs I might mill the wood a bit heavier if i were using cedar . these chairs are a blast to make and to modify into several matching peices we made a double wide with a fixed table and a rocker and on and on these are a load of fun to play with and to pay for new tools for the shop.
-- when I am not on Lumberjocks I am on @ http://thisoldworkshop.com where we allow free speech
Eric Criss
#2 posted 402 days ago
I’m looking for as natural finish as possible. Will spar varnish appear or FEEL plastic-y like poly?
-- Eric
TopamaxSurvivor
13194 posts in 1847 days
#3 posted 402 days ago
Check out this http://www.penofin.com/faqs.shtml
thedude50
#4 posted 401 days ago
No it wont but see for your self buy a small can and apply it if the choice is splintering or peel off or a bit thicker of a finish which would you choose.
Topa those last few had me ROFLMAO I do hope that was a joke page cause if it was serious how the hell are they going to sell it now
thedude50
#5 posted 401 days ago
Actualy the only finishes that are natural so to speak are not going to save this lovely grain IMHO. I think no one wants to tell you cause they know what you want may not exist but lets say you use water based Thompson water seal like for a deck did you know thousands of people get redness from it when it has prolonged contact with the skin . My answer was based on 43 years of woodworking experience and I don’t give advise that I wont take as solid spar varnish is a varnish it is used on boats so you can see the lovely grain and it wont need re-sanding every 2 years and a re application. It is not perfect but, i think that your trying to preserve a piece of wood you expect to fail .and this is the best way to do that IMHO
thedude50
#6 posted 401 days ago
Ok now I have your attention here is a great third party story from the fine folks at FWW they dont have an embed feature on their share it link but here it is for you. oh when they say marine varnish it is the same thing ok! http://www.finewoodworking.com/item/13849/the-ultimate-outdoor-finish
TopamaxSurvivor
#7 posted 401 days ago
They make some stuff called Log-on that has 99% UV protection.
View doninvegas's profile
doninvegas
311 posts in 1079 days
#8 posted 401 days ago
I’ve been making Adirondack furniture here in Nevada for 5 years. What has worked here is a base coat of Cabot’s Timber oil thinned about 25% with mineral spirits (let it cure real well) then 3 coats of spar varnish. One of my first customers had me re-finish their chairs after 5 years in this environment. It holds up well.
-- "Courage is being scared to death -- but saddling up anyway."
thedude50
#9 posted 400 days ago
thanks for the second on the spar varnish Don I know it works I have used it for years I use danish oil or sam maloof oil and spar varnish it works great
Eric Criss
#10 posted 397 days ago
Advice for appling spar with HVLP?
-- Eric
doninvegas
#11 posted 397 days ago
I spray with the Earlex 5000 with the 2mm tip. I thin the spar a little maybe 10%. You can spray full strengh with no problems though.
View mmcafee09's profile
mmcafee09
29 posts in 444 days
#12 posted 397 days ago
I use Helmsman spar urathane, it is UV protection and goes on nice. I just use a sponge brush or natural. Look at my projects, the cedar adirondack rocker has about two coats on it. as well as the planter i just put on a few days ago. Hope that helps
-- The College Woodworker
Eric Criss
#13 posted 397 days ago
I settled on Varathane oil based satin spar. Hoping for raw wood appearance with little or no shine. Tomorrow I plan to shoot the first coat with HVLP before assembly to catch all the edges. Coats 2 and 3 will go on after assembly.
-- Eric
View KevinH's profile
KevinH
70 posts in 1979 days
#14 posted 397 days ago
I used spar varnish with UV protection on a cedar Adirondack chair three years ago and it’s holding up well in central Pennsylvania moisture. The varnish imparts an amber tint that deepens nicely with each coat.
-- Timing has a lot to do with the outcome of a rain dance. --Kevin in Happy Valley
thedude50
#15 posted 396 days ago
Way to go Eric. I cant wait to see your chairs, be sure to link them in to this thread when you put them up as a project so i will be sure to see them. I have used Varathane before and it worked well you should be just fine.
