| Forum topic by RussellAP | posted 403 days ago | 771 views | 0 times favorited | 21 replies | ![]() |
403 days ago |
I’ve never given much thought to hand planes before. I have a couple now that I have no idea about. I use them and they seem to work okay, but I don’t get those long curls like I see most of you get.
-- Failure does not stop me, it makes me try harder..... because I'm crazy. |
21 replies so far
#1 posted 403 days ago |
I’m a hand plane noob like you, but while researching the other day I found this page. Seems to have some good beginner info. -- Rex |
#2 posted 403 days ago |
^I think I’d probably spend the time on that transitional (the wooden one); I think it has far more potential than the metal one. I hate to promote my own thread but the guys in “handplanes of your dreams” are very approachable and they’ve surpassed my knowledge a long time ago. Hit them up with any questions that you have but beware, this hand plane stuff is addictive:) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#3 posted 403 days ago |
Your transitional (it looks like a Stanley #35) can certainly be made to be a fine smoother. It may take a little tuning and the transitional’s are a little harder to set. I can’t tell what the bench plane is, but it should be able to be tuned up to work well. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#4 posted 403 days ago |
Don, the black planer is one I picked up at HF. It’s cheap but does the job. The other is a stanley as you said. I got it at an antique store for about 18 as I remember. I want to learn about these planers and when i see a good one at an antique shop I can get it. As far as tuning goes, I have no idea what that means or entails. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#5 posted 403 days ago |
Welcome to the slippery slope. Once you get started its hard to stop. Here is what I typically do to tune a plane. There are several blogs (I have a few) and many other with much more detail. Make sure the iron is sharp. My blog about restoring will help. , just skip over the repainting stuff, everything else should be relevant. Look through some of the links I sent sent your way. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#6 posted 403 days ago |
Russell, I probably have an extra bailey or two if you would like to test drive. |
#7 posted 403 days ago |
Shane, I’m working on a 16”x4”x7” walnut block and it’s cupped on one side. Hand planing is the only thing I can think of to smooth it out. I don’t have a planer or jointer. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#8 posted 403 days ago |
Russell- the method I used for getting material (walnut, actually) into shape is here, hope it’s of some use… -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive |
#9 posted 402 days ago |
Smitty, I had my eye on a Stanley #5 earlier today. http://www.amazon.com/Stanley-12-905-14-Inch-Contractor-Smooth/dp/B00004UDKW/ref=sr_1_1?ie=UTF8&qid=1334647869&sr=8-1 -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#10 posted 402 days ago |
russell, I have a very nice Stanley #5 I just restored. I haven’t listed it for sale yet because I just finished it. Its probably one of the nicest one I’ve seen. It will be cheaper and better then the one you listed, I guarantee it. PM me if you’re interested. I have a few others as well. For flattening you’ll want a jack sharpened with a camber. Look ate Plane #1 or #3 that I have listed in the link above. Either will work well. You would then want a smoother, something like the ones you have. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#11 posted 402 days ago |
^Don is the man when it comes to refurbing these tools, Russell. Highly recommended. -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive |
#12 posted 402 days ago |
Agree with Don but I would also add - Make sure the mouth where the blade comes through is not chipped or cracked Make sure the blade and chipper match Make sure there is a chipper If you are buying an old plane – before you buy it, disassemble the blade and chipper down the the frog. and make sure there are no missing screws and they are tight. I have seen many planes where there are screws missing in the frog, the blade doesn’t advance or retract (should have a lot of slop), the blade adjustment for angle – works. If the person that is selling the plane has a problem with you inspecting the plane to this level – do not buy it. I do this in stores with new ones also. Remember, unless you are buying parts, this is a tool to be used – if it doesn’t work, its a waste of money. -- David in Damascus, MD |
#13 posted 402 days ago |
Don, can you tell me what that piece on the planer that moves left and right is for? -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#14 posted 402 days ago |
Shane. I’m started down the slippery slope here man. Are the planers you have for sale and how much. I’d be interested in any tool that will help me save time and turn out a better product. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#15 posted 402 days ago |
Shane, here is what I’m doing with some walnut chunks I got from Jim the other day. He ran them through his jointer for me so I could have a couple good flat sides to work with. My table saw was used to cut them down from there then a bit of planing and sanding. They look really nice. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
