Filling old screw holes when replacing deck boards
Forum topic by Matt_D posted 04-16-2012 04:34 PM 14960 views 0 times favorited 10 replies Add to Favorites Watch
View Matt_D's profile
4 posts in 2223 days
04-16-2012 04:34 PM
Topic tags/keywords: question deck
I am in the middle of a project to replace the pressure treated deck boards on the deck behind my house. The joists under the decking are still in relatively good shape so I’m planning to reuse them. The problem I have is that after removing the deck boards I am left with a bunch of screw holes in the joists. I’m worried that water will collect in these holes and accelerate the deterioration of the wood.
Before installing the new deck boards should I fill these woods with something to plug them up? If so, what type of wood filler would hold up to an outdoor environment like this?
Thanks for the help,
10 replies so far
View Dallas's profile
3599 posts in 2416 days
#1 posted 04-16-2012 04:41 PM
Pressure treated wood shrinks and swells with the weather. I wouldn’t worry about filling the holes.
As an addendum, I would take up the worst looking joist and cut it apart in many places to see how bad it really is. This is just for piece of mind. I rebuilt a deck awhile back for a friend and all the joists looked good until I started putting screws in. Three of the joists were of inferior grade SYP cut from the core and even using 5” deck screws I couldn’t get them to grab. I ended up cutting them out and replacing them.
View Doss's profile
779 posts in 2194 days
#2 posted 04-16-2012 04:56 PM
Grabbing some roofing paper and cover each joist if you’re that worried about it. Another option is getting out the caulking gun and filling each hole with a dab of silicon.
I’d only do this if the new decking wasn’t going to cover the holes.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View SWM's profile
94 posts in 2987 days
#3 posted 04-16-2012 05:14 PM
Great question. This is one of those things that I would think about too. My guess is it probably doesn’t matter, but if you are like me, you might lose sleep a couple of nights worrying about the “best” way to rebuild that deck. I just happened to read this artlcle over the weekend and I’m seriously considering adding to my next deck rebuild this summer. Hope this helps and let me know how it goes.
-- Working on a retirement hobby, only 30 more years to practice!
View MrRon's profile
4667 posts in 3173 days
#4 posted 04-16-2012 05:49 PM
You could slather on a coat of tar on the top of the joists.
View doughan's profile
96 posts in 2520 days
#5 posted 04-16-2012 06:09 PM
Any thing you put over the joist that will slow the drying between rain storms only accelerates the rot process.Tar and tar paper won’t do any good at all
use something that will penetrate the joists and repell water from ever getting into the interior of the wood.
View Doss's profile
#6 posted 04-16-2012 06:44 PM
Two details I forgot to ask (and I think everyone else has too) is where you are located and how much rain is this deck going to get?
Help us help you.
View GaryL's profile
1099 posts in 2760 days
#7 posted 04-16-2012 06:50 PM
Don’t worry about filling the holes, cover them up as mentioned earlier by Doss. A step better would to use ice and waterguard, even better would be a self adhesive membrane for flashing windows. All your new fasteners would self seal in the membrane to prevent any future water intrusions. Whatever you use, saddle it over the joist.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View Don W's profile
Don W
18658 posts in 2497 days
#8 posted 04-16-2012 07:05 PM
I second what Dallas wrote. Won’t the new deck boards cover most of the holes anyhow?
-- - Collecting is an investment in the past, and the future.
#9 posted 04-16-2012 07:26 PM
I am in northern Illinois so the deck will be getting plenty of rain and snow. It sounds like the holes won’t be such a big deal so I may just leave them.
View ChuckC's profile
827 posts in 2864 days
#10 posted 04-16-2012 07:48 PM
You probably don’t have to do anything but you could always put the screw back in the hole, under the new deck boards and flush with the top of the joist.
