Help for new table saw user!
Forum topic by PSL posted 04-15-2012 11:51 PM 3216 views 0 times favorited 9 replies Add to Favorites Watch
View PSL's profile
PSL
5 posts in 2435 days
04-15-2012 11:51 PM
Topic tags/keywords: tablesaw blade question
Hello all,
New to woodworking and Lumberjocks.
Trying to figure out what’s going on with my new Ridgid R4512, (only 35 days old used only on a few small projects)
After running great for weekend projects over the last thirty days it suddenly started making a “loud” squeal on startup. This is a high pitched chatter or whine that last one to two seconds then the saw runs quite as usual.
I did a search on numerous sites and followed the advise offered for this type of problem: checked the belt, re-tightened the belt, used belt dressing, checked the arbor for free movement with out the belt, checked the bolts/washers holding the blade…
While checking the saw I began to rotate the blade rotating it back and forth several inches in each direction. I moved the blade around the different points of the blade so I could rock it back and forth around the whole rotation of the blade.
What I found was that at one point on the blade, as I rotate the blade rapidly back and forth there is a metallic grating sound. At first I was sure there was something rubbing against the blade as it sounds like a metal on metal scraping sound. I checked and the blade is completely free and clear…
I don’t know if this metallic sound is normal or, is this what’s causing the screeching on startup…
Any thoughts or help would be greatly appreciated. For what it’s worth the saw works great. Cuts like a champ. I just don’t know if the sounds foretell of a problem or not.
I can always return the darn thing to HD but seeing as how I’ve added a router table and modified the wings to just were I want them I’d rather not repeat all that work if anyone has a thought on the problem.
Thanks.
9 replies so far
View knotscott's profile
knotscott
8148 posts in 3577 days
#1 posted 04-16-2012 12:37 AM
Just a guess….sounds like it could be bad bearings to me.
View BernieMay's profile
BernieMay
28 posts in 3239 days
#2 posted 04-16-2012 01:04 AM
The screeching sounds like a loose belt between motor and arbor. the metalic sound could be bearing in arbor or motor.
View Lee Barker's profile
Lee Barker
2170 posts in 3052 days
#3 posted 04-16-2012 02:12 AM
Bernie brings up a possibility I hadn’t considered—a motor bearing. By loosening and removing the belt, you could isolate that.
Belt dressing is tricky stuff. Most belts and pulleys don’t want it; in some cases it can be sticky enough to make the belt not want to let go of the pulley and you get slapping and pulsing (depending on what kind of motor mount).
I think your turning the arbor manually revealed the source of the noise: A failed bearing.
So now it’s time to weigh the guarantee, if any, against the likely downtime if you get it repaired by the seller.
I am not familiar with that saw and how easy it is to get to the bearings, but many LJs have done this replacement so if your decision is to replace the bearings yourself, I suggest you start a forum thread asking for experience on your kind of saw.
Manufacturers are tending to cut more and more corners these days, and even if they’re saving only a couple bucks on bearings on a given saw, that’s real money when you multiply it times the number of saws manufactured in a day.
I hope you can get it up and humming quickly.
Kindly,
View RussellAP's profile
RussellAP
3104 posts in 2488 days
#4 posted 04-16-2012 03:25 AM
A couple of questions.
1, do you use dust collection on the saw?
2, did you install the dust collection port on the bottom of the saw, that black bottom with a 5” hole in it?
If you noticed the directions when you put the saw together, it said that if you install the dust collection system (DC) you need to be sure and hook up the DC to the saw or it’s a fire hazard.
It could be that the saw motor got encased in dust and got too hot.
I did put the dust port on my 4512 and I don’t use DC but I do make sure and clean it out every time I use it.
Just a thought.
And Welcome to LJ.
View oluf's profile
oluf
260 posts in 3241 days
#5 posted 04-16-2012 03:26 AM
I would remove and replace the blade. The nut may be loose and the blade slips on the arbor shaft on start up. It’s worth a try.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View PSL's profile
PSL
#6 posted 04-16-2012 04:34 AM
Thanks to all for the input.
I was using the saw today and noticed a slight metallic grating sound now creeping in while the blade spins down after shutting it off. It seems like its a bad bearing…
I did concert the dust port, and no I was not using dust collection… I checked the motor and it doesn’t seem encased in dust but may have ingested more than I can see from the exterior.
The more I listen to it, the more it seems to be coming from the arbor bearings… Just seems surprising to have failed in only 30 days. I guess you get what you pay for.
I am going to exchange the saw at HD as its in warrantee. Other than the lack of dust collection that might have overheated the motor, is there anything I could do, with normal use and what seemed to be proper set up and limited use to damage the bearing?
Again really appreciate all the advice and have enjoyed visiting this site immensely. Hope to hear a saw humming soon.
Thanks,
Peter
View Boxguy's profile
Boxguy
2762 posts in 2469 days
#7 posted 04-16-2012 05:27 AM
I think I have a saw made by the same company. Did you change the blade to a thinner one? If this saw is like mine, I installed a thinner blade and it slipped into a groove on the threaded shaft on the arbor. The results were what you described. Just as a quick test, put a thicker blade on and see what happens. The fix is a thick washer behind the blade.
Second idea. Have you checked the set screws on the pulleys? They need to be seated on the flat part of the motor shaft and the arbor shaft. If they are tight, but lined up with the round part of the shaft and not the flat part, they will spin when there is start up pressure. If there is a rounded or square key, it too needs to be lined up and in far enough to join the pulley to the shaft.
The bearing sounds like a likely culprit with your spin test.
-- Big Al in IN
View Tomj's profile
Tomj
204 posts in 2583 days
#8 posted 04-16-2012 06:01 AM
I’m not sure if this will help but when I bought my dust collector and first turned it on I would hear a screeching sound on start up and then it would lower. I wasn’t sure what it was, I asked on here and some people said bad bearings, impeller rubbing etc. What it turned out to be was the fan at the back of the motor for cooling was rubbing up against a dent in the cage surrounding it. I wouldn’t hear it after start up because the motor would be running at full speed just barely touching this small dent and sort of pushing the dent in the cage up. I just took the cage off and pushed the dent out (problem fixed). Good luck.
View Tomj's profile
Tomj
#9 posted 04-16-2012 06:04 AM
Also I’m curious about this as I might be buying this table saw soon so I would like to know of any defects such as your problem or the blade going out of alignment at different heights. Again good luck.
