drill doctor, useful or useless??
Forum topic by Carwyn Owen posted 04-15-2012 10:21 PM 4302 views 0 times favorited 21 replies Add to Favorites Watch
View Carwyn Owen's profile
Carwyn Owen
22 posts in 2732 days
04-15-2012 10:21 PM
Topic tags/keywords: jig drill-driver drill press sharpening
Me and my brother(who is more interested in metalwork) are considering on buying one of these models, but are not sure on which one or even if their any good. just wandering if anone had any ideas or better jigs/ ways to sharpen drill bits. also a note that we are in the uk, so us products only will not be of use.
thanks again.
this is the link- http://www.drilldoctor.com/
-- “Woodworkers are only thieves of each other’s ideas.”
21 replies so far
View nailbanger2's profile
nailbanger2
1041 posts in 3227 days
#1 posted 04-15-2012 10:29 PM
I’ve got one, have had it for 3 yrs or thereabouts, and I have yet to use it.
-- Wish I were Norm's Nephew
View Mickey Cassiba's profile
Mickey Cassiba
312 posts in 3115 days
#2 posted 04-15-2012 10:59 PM
I’ve used similar tools in a machine shop environment. While I cannot vouch for the DD personally, the mounting jig(collet) is remarkably similar to the units I’ve used. The ones I used produced consistent results, especially on the smaller bits. I’m gonna watch this one…I’ve been considering them too.
-- One of these hammers oughta fix that...
View Loren's profile
10477 posts in 3731 days
#3 posted 04-15-2012 11:07 PM
For people with shaky hands or poor eyesight it may be useful.
I have a DD somewhere in my stuff my dad bought on sale
at Sears. I have never used it.
Here’s why:
Standard twist drills are shaped for drilling metal, not wood. It
is easy to resharpen them with the same bevel on a grinder,
except the really small ones can be tricky. If I am sharpening
a bit for wood, I almost always regrind it to a cabinet-maker’s
point, which is like a brad point. It is not that hard to do, though
with the small drills it takes finesse.
Carwyn Owen
#4 posted 04-15-2012 11:11 PM
thanks. useful thanks, were not sure weather the price is worth it, you can buy a lot of drill bits for the price of th sharpener?
View DIYaholic's profile
DIYaholic
19634 posts in 2758 days
#5 posted 04-15-2012 11:18 PM
I too have considered the DD. Like you said, for the price of a couple of drill bit sets one can purchase a DD. I will be watching this for responses from experienced users.
Thank you, for posting a question that I’m sure many have been wanting to ask!!!
View mikeho's profile
mikeho
52 posts in 3205 days
#6 posted 04-15-2012 11:29 PM
Luv it. I have had one in my mechanics shop for years and have had awesome luck with it. Nice when drilling heavy metal and bit dulls within seconds its sharp and drilling again.
-- Mike, Thedford NE
View Viking's profile
Viking
880 posts in 3278 days
#7 posted 04-15-2012 11:31 PM
I have one of the original Drill Doctors and use it all the time on my metal drilling bits. It works very well of you set the bit properly in the bit holder.
For woodworking I use brad point bits.
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View davidroberts's profile
davidroberts
1027 posts in 3569 days
#8 posted 04-15-2012 11:38 PM
I have the base model I bought on clearance for $20, unopened box. Works for twist and masonary bits. I ruined two bits before I actually took the instructions to heart. You have to set the bit in the collet properly, and watch how you do the rotations.
The trick is to use one hand to hold the collet in place after a rotation, which gives you time to reposition the other hand to turn the collet. This keeps the collect positioned all the time. After that, I spent the next 4 hours sharpening around a hundred bits of all sizes that would fit. I don’t throw anything away. I was shocked at the number of masonary bits I had stashed.
The results mostly exceeded my expectations. Most of the bits were sharpened to like new. For me, the base model worked best on 1/4” and up. I got 1/8” bits sharp but I had to be more careful in the setup. I’ve heard the newer and more expensive models will sharpen brad point bits, and I believe cut a brad of some sort onto a twist bit. As they say, your milage may vary.
-- Better woodworking through old hand tools.
View Jim's profile
Jim
120 posts in 4081 days
#9 posted 04-15-2012 11:54 PM
I have an older model at home and a newer one at work. The one at work I use all the time and have more than paid for it self not replacing bits. Easy to use and quick.
-- Jim in Cushing Oklahoma
View Stephenw's profile
Stephenw
273 posts in 2469 days
#10 posted 04-15-2012 11:55 PM
I have a Drill Doctor 400 that has always worked well for me. It came with the 1/8”-1/2” and the 1/2”-3/4” chuck. It only sharpens to 118°, but will also do split points. Meticulous attention to detail is required when chucking the bit. Otherwise, poor results will be attained.
I’ve seen the video for the newest model on YouTube. It will do spade bits, but not brad point bits. Most of the reviews on Amazon say the spade bit feature doesn’t work very well.
davidroberts
#11 posted 04-16-2012 01:04 AM
StephenW got it right, the newer models will make and sharpen a split point, not brad points. If I had to guess, a lot of the amazon reviews are by folks not taking the time to learn the system. A file and slip stone will sharpen up spade bits, especially if the bit is placed in a jig to make the angle more easier to work from and maintain, same with router bits.
View gfadvm's profile
gfadvm
14940 posts in 2773 days
#12 posted 04-16-2012 02:57 AM
My Drill Dr has paid for itself many times over but a metal worker will need one more than a woodworker. I have the model that sharpens up to 3/4” bits. Small bits are usually inexpensive but when you get over 1/2” they get a lot pricier.
TopamaxSurvivor
18337 posts in 3759 days
#13 posted 04-16-2012 03:04 AM
I have one I used for very small drills, but I sharpen most of them by hand. It worked ok. No complaints.
View mark4345's profile
mark4345
71 posts in 2506 days
#14 posted 04-16-2012 03:52 AM
I have the newer model which also does spade bits. I think its great i have used it a lot and it sharpens bits to new condition. I think it works excellent especially on spade bits, i work as a carpenter also so my bits get a lot of use.
View redryder's profile
redryder
2393 posts in 3185 days
#15 posted 04-16-2012 07:29 AM
I have had one for a long time and have tried many times unsuccessfully to sharpen drill bits with it. I have come to the conclusion that I could perform brain surgery before I could ever sharpen a drill bit. I own more used dull drill bits than anyone…...........
-- mike...............
