| Forum topic by intheshop | posted 430 days ago | 583 views | 0 times favorited | 8 replies | ![]() |
430 days ago |
Topic tags/keywords: question I’m building a new router table top. I’ve laminated two pieces of MDF (3/4”) and covered with Formica on both sides. I want to add hardwood banding around all edges. Will simply gluing the hardwood to the edges be sufficient or should I use some sort of metal fastener? I intended to use pocket screws, but when I drilled the first pocket hole it came out right in the center seam and slightly split the joint between the MDF slabs. How have you guys done it? -- Cole - Rydal, GA |
8 replies so far
#1 posted 430 days ago |
I always use countersunk screws. And if you want you can plug them and sand them down smooth. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#2 posted 430 days ago |
I just glued mine on my router table, just make sure that your edges are clean and straight, and you use plenty of clamps and it should hold for many years. (And look a little prettier than screws) To some that doesn’t matter but I am not one of those. All my shop fixtures and furniture match :) -- Lucas, "Someday woodworks will be my real job, until then, there's this http://www.melbrownfarmsupply.com" |
#3 posted 430 days ago |
Glue and nails is the easy way to do it. Countersink the nail |
#4 posted 430 days ago |
Just glue but coat both surfaces. Any fastener into the edge of MDF is looking for a place to bulge. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#5 posted 430 days ago |
Good point Lee. I seldom edge band MDF and I guess I haven’t |
#6 posted 430 days ago |
The contact glue that you used on the formica faces would probably work real good on the banding also. -- As ever, Gus-the 74 yr young apprentice carpenter |
#7 posted 430 days ago |
I banded mine with oak using just (titebond III) glue, then laminated it and chamfered the edges… -- Rick |
#8 posted 429 days ago |
Hey, everybody. Thank you for all of your suggestions. After consideration, I’ve decided to simply glue with Titebond III. I’ll use plenty of clamps as you suggested LukieB.
@Bluepine38: I like your idea of using the contact cement, but I’ve mitered the corners and due to the precision required in placing the banding I doubt if I’d have much success getting it right. -- Cole - Rydal, GA |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15977 |
Hand Tools
2095 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2776 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
