What tool am I missing?
Forum topic by TelescopeMaker posted 04-13-2012 05:32 PM 1587 views 0 times favorited 18 replies Add to Favorites Watch
View TelescopeMaker's profile
TelescopeMaker
77 posts in 3070 days
04-13-2012 05:32 PM
I’m casting about for ideas. I’m thinking of getting another tool, and I’m curious what you would get if you already had:
table saw <old>
bandsaw <ridgid><makita>
6” grinder <delta>
router <ridgid>
12” benchtop drill press <ryobi>
small air compressor and brad nailer.
dust collector <cheap>
I had a 12” SCMS, but I never used it and recently sold it because it was in the way.
I might have around $300 to spend.
I’m thinking of making a fliptop cart with the grinder and maybe a new spindle sander or a disk sander.
I am just now finishing a cart for the DP and Planer.
I’ve got other hand power tools. drill, circ saw, palm sander, dremel, biscuit joiner, belt sander, recip saw, saber saw.
I’ve also got a collection of hand tools, various planes (#7 jointer #4 1/2 jack, smoothing plane, a scrub plane I made, several wooden planes I inherited from my family)
My shop is 12×19, and I have very little room left :)
I have made boxes, and bottle stoppers and calendar frames. and I have made shelves and a hutch, and would like to make a coffee table, and a bedframe, bathroom cabinet/vanity. I like the arts and crafts style, stickley, greene&greene. simple things. I make telescopes too, but that’s a different story :)
I’ve thought of maybe a jointer, but really, the large #7 hand jointer and the jack plane do an excellent jobs. A router table, perhaps, or at least as an adjunct to the rails on the table saw.
A new/used table saw isn’t out of the question either, but I think I’ll have to spend a bit more than $300.
-- Telescope Maker, Woodworker, Brewer, Gizmologist, Gardner, Lawn Mower
18 replies so far
View newwoodbutcher's profile
newwoodbutcher
746 posts in 2899 days
#1 posted 04-13-2012 05:46 PM
A thicknes planner would be my next choice
-- Ken
View Jim Finn's profile
Jim Finn
2661 posts in 2971 days
#2 posted 04-13-2012 08:48 PM
I would opt for a 6” x48” bench top belt sander myself. Making the small crafty items that I make, that sander is the most used tool in my shop.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
View crank49's profile
crank49
4032 posts in 3020 days
#3 posted 04-13-2012 11:06 PM
I don’t know why you never used the SCMS?
When I go to build something, I work in stages.
Joint and thickness.
Then rip or cut to length. Here I use my miter saw as much as the table saw.
Then details like holes, rabbits, bevels, etc.
View MrRon's profile
MrRon
4851 posts in 3293 days
#4 posted 04-14-2012 12:04 AM
It depends on the kind of projects you do. Think about a time when you needed a certain tool that you didn’t have. Maybe that is the next new tool. I probably wouldn’t pick a sander without updating the DC system. One tool I could recommend is a cordless impact driver; greatest thing since sliced bread. How’s the saw blade? A good saw blade improves your work.
View davidroberts's profile
davidroberts
1027 posts in 3535 days
#5 posted 04-14-2012 12:33 AM
I usually buy a tool or tools I need when I do a specific project. Or build it better, quicker. Let the projects guide your tool selection, else you may have a tool sitting around for months not earning its keep. The exception is old solid great value tools that don’t come along often. And that could be any type of power or hand tool. The other exception is shop and tool accessories and upgrades, like MrRon suggested, a good grade saw blade, dado set, Kreg kit, clamps, hock or IBC plane blades, chisels, vice, wood, wood, wood. The final exception is tool clearance sales, 1/2 price, deep discount is good stuff.
-- Better woodworking through old hand tools.
View dbhost's profile
dbhost
5736 posts in 3281 days
#6 posted 04-14-2012 12:43 AM
A planer would be my next choice… You can joint on a planer, but you can’t plane on a jointer…
View RussellAP's profile
RussellAP
3104 posts in 2336 days
#7 posted 04-14-2012 12:43 AM
Miter saw. And you have just about the right amount of $’s. It’s a lot easier than a table saw for cross cuts and we all make tons of cross cuts.
TelescopeMaker
#8 posted 04-17-2012 03:50 AM
Meant to make it clearer. I have a planer, a makita… something happened to my post.
A miter saw might be it. I just don’t need a huge 12” scms, but a small one would be fine. Space is a huge consideration. If I need to make big cuts, the table saw is fine.
Just sharpened the table saw blade about a month ago. Nothing like a sharp blade. A box joint blade would be nice. A hock blade, yep.
I’m actually going to try my hand at making clamps.
The best tool is the one I’m going to build… a real bench.
117159 posts in 3626 days
#9 posted 04-17-2012 04:22 AM
Upgrade your BT3000 to a used Ridgid contractor saw. or a lathe for your Telescopes.
View bondogaposis's profile
bondogaposis
4819 posts in 2400 days
#10 posted 04-17-2012 04:32 AM
I would get a lunch box planer.
-- Bondo Gaposis
View Loren's profile
10476 posts in 3697 days
#11 posted 04-17-2012 05:17 AM
You must be skilled indeed if you can joint and square
your boards confidently with hand planes. Personally
I find jointing is not so difficult but squaring can be
very tricky with hand planes. A jointer is an expedient
to the craftsman who wants to eliminate all the planing
and checking with a square.
Smitty_Cabinetshop
15373 posts in 2668 days
#12 posted 04-17-2012 05:57 AM
How about a hollow chisel mortiser? It makes the mortise and tenon joints you’ll use on those larger projects so much easier…
#13 posted 04-17-2012 07:14 AM
Or get yourself some sweet mortising chisels.
View knotscott's profile
knotscott
8078 posts in 3425 days
#14 posted 04-17-2012 07:23 AM
If you use dimensional wood, a planer is a game changer…
View steliart's profile
steliart
2735 posts in 2737 days
#15 posted 04-17-2012 07:31 AM
I would have gone with a planer/jointer combo
-- Stelios L.A. Stavrinides: - I am not so rich to buy cheap tools, but... necessity is the mother of inventions !!!
