stabilizing corn cob pen blanks
Forum topic by HokieMojo posted 166 days ago 364 views 0 times favorited 3 replies Add to Favorites
View HokieMojo's profile
HokieMojo
414 posts in 265 days
166 days ago
Topic tags/keywords: corn corn cob corncob pen blanks
I’m just wondering if making corn cob pen blanks is something that a person could do on there own or if buying the blanks is the best way to go. I couldn’t find much on the web about the process, but it sounds like you would need to somehow soak the cobs in some sort of resin. Just wondering if anyone has tried this.
View Betsy's profile (online now)
Betsy
1883 posts in 432 days
166 days ago
I’ve not tried doing this, but I would think that the process would involve more time and patience than would be worth it. I think I’d just buy the blanks and use the time that it would take to make your own to turn pens. Just my thought.
-- Betsy - GO BUCKS!
View Terry's profile
Terry
26 posts in 170 days
165 days ago
Cob pens are fragile. Even the stabilized cobs are touchy. When I get close to the base of the kernal pocket I start to apply thin CA and remove material very gently. I then reapply the CA and remove material very gently….. When you reach the stage of applying CA never and I mean never make your cut from the middle of the blank to the end. Always come from the end into the center. Did I say remove material very gently? A razor sharp skew is the tool to use. All that being said sometimes no matter how careful you are the cob just comes apart. My recommendation would be to use Cigar kits not slimline kits for cobs.
Terry
-- When the chips are down that means the buffalo is empty.
HokieMojo
165 days ago
Thanks for the posts guys. I have to admit, the final product looks so cool, but it sounds like this is something that I should just start with pre-made blanks. Hopefully I’ll have something to post on this in the not too distant future. Thanks!
Bookmark And Share This Page
