Central Machinery - item#44836 12 speed benchtop drill press
Forum topic by Richard posted 04-12-2012 07:39 PM 3880 views 0 times favorited 2 replies Add to Favorites Watch
View Richard's profile
Richard
1917 posts in 2774 days
04-12-2012 07:39 PM
Topic tags/keywords: question drill press
I got this drill press a few weeks ago and am about to start on a table for it. My question is does anyone else have it and know where I can get an extension for the handle to raise and lower the table since the standard handle will hit the table after it is installed.
I looked at some local hardware stores and could not find the right parts to extend it. It should be just a simple coupleing and another rod of the right size but the coupling is what I am not finding.
Thanks
2 replies so far
View crank49's profile
crank49
4032 posts in 3055 days
#1 posted 04-12-2012 08:22 PM
I have the 44836 12 speed drill press.
Hated it.
Stroke too limited. Work height too limited.
Converted it to a mortising machine.
Bought the 38142 16 speed, 3/4 hp drill press.
Love it.
An extra inch of stroke.
12 more inches of work height.
An extra 1/4 hp; up to 3/4 hp.
Weighs 40 more pounds; smoother, quieter.
Much, much better.
A simple way to turn the lift gear when a table is in the way is remove the handle and replace it with a coupling nut, like you join two lengths of all-thread rod with. Might need to drill and tap a set screw in the side. Then use a ratchet wrench, with an extension if needed.
Richard
#2 posted 04-12-2012 10:55 PM
Thanks for the tip. I don’t have room for the larger model, wish I did since I could have gotten a nice one on
CL around the same time as I got this one. The short stoke is not big issue for what I do now, if I get a bigger unit I will convert this one to a drum sander.
