Douglas Fir Bench Top
Forum topic by Brohymn62 posted 400 days ago 802 views 0 times favorited 4 replies Add to Favorites Watch
View Brohymn62's profile
Brohymn62
105 posts in 420 days
400 days ago
Hello,
I am in the process of planning a work bench build. It’s going to be made of reclaimed douglas fir, the timbers I have are 4” x 12” x 20’.... what would be the optimal size to mill that down to for the top glue up? I’ve been doing some digging online and found several good looking tops made of 3 1/2” x 3 1/2” pieces glues up to final dimensions of the top. The top will probably be 30” wide x 60” long.
-- - Chris G.
View bondogaposis's profile
bondogaposis
1236 posts in 516 days
#1 posted 400 days ago
I’d just glue 2 pieces together for a 24” x 4” top.
-- Bondo Gaposis
View jmos's profile
jmos
637 posts in 534 days
#2 posted 400 days ago
3.5” to 4” range for thickness in a soft wood top is great. For width, bigger is better. The fewer pieces you laminate the less gluing up, alignment, and flattening you have to do. If I could have gotten a single slab for my top I’d have grabbed it.
If the 12” spans don’t include the pith (center of the tree, which makes them much less stable) and you can manage them (can get tricky maneuvering a heavy slab across a jointer or through a planer), I’d use two pieces. If you really want 30” (nothing wrong with that) than use three 10” wide. If you’re worried about movement, you can cut them down further and alternate growth ring direction, but I’d keep them as wide as you can manage.
-- John
4864 posts in 1813 days
#3 posted 400 days ago
If ripped and glued so the top face of the bench is in effect
quarter-sawn there would be some advantage in stability
across the bench. The wood will move more evenly
and you may avoid the seasonal bulges and valleys that
can occur with flatsawn slabs.
View DrewM's profile
DrewM
177 posts in 1164 days
#4 posted 400 days ago
I used 14 doug fir 2×4s for my workbench top, so far it has been working great for me.
-- Drew, Delaware
