Need your feedback: Climate control vs. bowing/warping
Forum topic by Randy Sharp posted 526 days ago 423 views 1 time favorited 15 replies Add to Favorites Watch
View Randy Sharp's profile
Randy Sharp
198 posts in 569 days
526 days ago
Topic tags/keywords: question
Need some feedback, fellow woodworkers.
Let’s say I buy a 1×8x10 red oak board from the controlled climate of my local home improvement store. The stock is straight…looking good and square to make a cabinet door frame (flat panel door using 1/4” plywood insert).
My shop is not climate controlled and after a day or so in Mississippi heat and humidity (85 degrees at say, 70%), it begins bowing and/or warp. A friend recommends I slightly dampen the cupped side and lay if flat to correct the problem. No good. After it bows, taking it back to a climate control unit is too late too. It won’t go back straight.
What I’m thinking is that I keep it in my climate controlled house from the store until I’m ready to cut, take it to the shop and either build the frame immediately, or take the pieces back inside for assembly later. The board will spend less than two hours out of climate control during cutting.
Does that sound workable, or are there other solutions?
Thanks, Randy
-- Randy, Tupelo, MS ~ May I become more like the Master Carpenter every day.
View GaryK's profile
GaryK
9536 posts in 885 days
526 days ago
I think that first I would just wait a week and see if it equalizes. It will probably flatten out on it’s own.
Give that a try before you do anything else.
View Greg Wurst's profile
Greg Wurst
716 posts in 729 days
526 days ago
I usually cut wood on my table saw in the garage. I leave the wood in my house until I cut it and take it back in immediately after I am done. Wood I used to leave in the garage would warp like that for me, and keeping it in the house has greatly minimized that problem.
View Russel's profile
Russel
2063 posts in 836 days
526 days ago
I’ve had some luck clamping boards to a flat surface for a few days while they equalize to the new environment. It’s worked for twisted boards up to 5 feet.
-- Working at Woodworking www.VillageLaneFurniture.com
Randy Sharp
526 days ago
I guess once you rip it, internal stresses can cause it to warp and cannot be reversed?
View Catspaw's profile
Catspaw
186 posts in 712 days
526 days ago
This is a concept I can never understand. Everybody spends all this time trying to control the environment of the wood, hoping nothing happens to it.
What happens when you make something out of it and send it off some where and the new conditiions aren’t the same? What happens if your A/C breaks down for a few days. Or the heater. Will the piece of funriture suddenly go all warpy?
I see no sense in building with something that is going to warp. IMHO, if it’s going to warp when I don’t control all the environmental conditions, I don’t want to use it in anything. It would seem to me if it’s moving that much, there are internal stresses that you won’t be able to get rid of short of using it in short lengths and such.
And finishing (sealing) the piece is only marginal help.
-- arborial reconfiguration specialist
View BroDave's profile
BroDave
86 posts in 711 days
526 days ago
I believe that internal stress which causes a piece to warp is beyond anyone’s control, but warping due to environmental conditions can be controlled, at least while you have the project in your hands.
My thinking is if I can store and build a piece under the same conditions as it will be normally subjected to in someone’s home then the movement will be minimal, especially if I have finished/sealed the piece to prevent it from absorbing moisture.
Anything finished with poly is going to absorb and loose moisture almost as if it were never finished, unless it built from plywood or MDF which doesn’t move much to start with.( China products not included)
I stopped using poly finish, Shelac and Laqure only on solid wood for me.
Of course I may be way off the mark in my thinking, but it makes me feel better. :)
Randy Sharp
525 days ago
My thoughts are along the same as BroDave. Per Catspaw, you’re right in the “hoping nothing happens to it” theory. If I spend $40 on a single board, in the back of my mind, I’m saying “I hope it’s a good one this time.” Is it a question of luck, or are there things the average guy can look for in the wood that (i.e. grain pattern) that can tip him off?
View jcees's profile
jcees
552 posts in 696 days
525 days ago
I live in FL so I know a thing or twelve about moisture uptake and release. That’s why I don’t buy “finish” wood from the Big Box store anymore. They want too much for it anyway. BUT if I were stuck with that as an only option then I’d treat the stuff like it was rough. In other words, it’s going to get a lot smaller before I’m through. I would cut my parts oversize, let them stabilize in the shop then square the pieces to almost finish size and let them settle a bit more before trimming them to final size. Taking it in steps is the surest way I’ve found to deal with the demons of distortion. Hope this helps.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
View dirtclod's profile
dirtclod
165 posts in 757 days
524 days ago
Don’t let it acclimate to your uncontrolled shop. That’s asking for trouble no matter what form the wood is in. Your shop is not dry enough to leave wood in it, unless you plan on storing it there and putting it in a kiln, or other drying method later, before you use it.
You’re right – move it to a controlled environment when you are not actually working on it.
-- Wonderful new things are coming! - God
View davidtheboxmaker's profile
davidtheboxmaker
372 posts in 702 days
511 days ago
I don’t have massive climatic effect on the timber I use, but I do take steps to let the wood settle before I use it. Typically, I buy some wood, then let it sit in my workshop for a month or two, then resaw and let it settle for another month or two before taking it down to final thickness. Having done that, I then let it lie for a while before I use it. Having done this, which mainly consists of leaving the wood alone for a time, I then check the timber is flat before I use it. I do get the occasional piece that twists so as to be unusable due to internal stresses. That becomes scrap. The vast bulk of timber I use does not show any distortion, and is stable when used.
View accalades's profile
accalades
5 posts in 959 days
508 days ago
always upsetting.
-- chris lambkin
View Al Killian's profile
Al Killian
271 posts in 650 days
508 days ago
I try to let the wood sit for a week or two. Then use it uo after it is cut or there is a good chance it will move more.
View John Fry's profile
John Fry
73 posts in 597 days
507 days ago
Randy,
The question nobody has asked is,..... Did you store the wood properly?
The biggest problem people have with wood warping after getting it home (or after freshly milling), isn’t just the change in RH conditions, it is the way it was stored! How did you store your new board? Sitting on the bench? Stacked against another board vertically? If the board is stored in a position that only lets air get to one side, it will change moisture content on that side and the other side won’t. This will warp 100% of the time. Did you allow your high humidity air to freely flow around the board for equal exposure?
I know folks will disagree, but I NEVER take the time to acclimate wood in my shop. What is the point? First of all, I can’t afford to sit around and wait week after week, or I’ll never get paid. I live in the high desert of So. Cal. and it is generally around 12 to 12% RH. I have sold furniture to clients in Houston, Washington DC, and upstate New York. These are very humid locations and I’ve never had a call back. Acclimating lumber to my shop and then selling to these locations seems silly!
If you handle and store your wood properly, stack and sticker (or clamp) after milling and exposing fresh surfaces, and keep your material flat at all times during construction, then build with proper techniques to allow for expansion and contraction, you should have no problems. And, you should be able to locate your piece in any climate zone.
I live by the motto…..”The safest place to store your lumber is in your project!”
-- John, Chisel and Bit Custom Crafted Furniture, www.chiselandbit.com
View grumpycarp's profile
grumpycarp
232 posts in 643 days
507 days ago
The process of kiln drying wood can lead to a condition called “case hardening” which is not at all unlike what happens to metal. Except with metal it is a condition often created on purpose and with an end result in mind. With wood it happens because the wood is dried too fast leading to a situation where the outside and the inside dry at different rates. This causes an imbalance between the two which builds in stress and upon cutting releases those stresses. I have had kiln dried 2×12 western red cedar literally explode upon being crosscut halfway.
Acclimate as you have time and space for. Ensure proper airflow to all sides. Rough mill oversize and allow time to stabilize. Mill to final size and assemble as soon as is practical.
As GaryK said (and I paraphrase) “At first, do no harm” it will probably even out.
The other issue could be stock selection. NO BULLSEYES! Check the grain. Quartersawn stock is pretty darn stable, rift sawn far less so. And anything close to the heart of the tree will just go wonky. Just because it’s on the shelf and expensive doesn’t mean you should use it. I go through this with people on my end constantly.
And lastly, your joinery should allow for wood movement. If the piece is shipped from John Fry’s shop in SoCal at 12% rh to your house in Mississippi it will move quite a bit if made from solid wood. This should be accommodated in material selection, grain orientation and choice of joinery.
Just my five buck a gallon opinion. . .
View Chris 's profile
Chris
1469 posts in 888 days
506 days ago
This is the very reason why I buy rough stock now instead of dimensioned. When I started doing this I had far fewer issues. I too live in a VERY high humidity area; roughly 80 to 90% depending on the day.
With rough lumber I can dimension oversize then after the stresses (bowing, warping, checking, etc) occur I have the extra size left to correct it….
-- Chris
