Blade tip profile for box joints
Forum topic by Jim Rowe posted 04-12-2012 03:53 PM 1364 views 0 times favorited 4 replies Add to Favorites Watch
View Jim Rowe's profile
Jim Rowe
1038 posts in 2308 days
04-12-2012 03:53 PM
Topic tags/keywords: box joint jig saw tooth profile question
I am thinking of making a box joint jig for use on my small table saw (Scheppach TS 2000) using one of the designs from Stumpy or Matthias. The saw’s blade diameter is 200 mm or 8 inches in old currency. Can anyone advise me on the best / correct tooth tip profile for my saw blade as I am afraid that the alternate angled one I presently use will not give a flat even bottom to the joint. As the jig will be used for small boxes I want to ensure that all the joint work looks neat and tidy. Thanks
Jim
-- It always looks better when it's finished!
10380 posts in 3643 days
#1 posted 04-12-2012 04:24 PM
Flat topped grind.
The blade may be hard to find but a saw sharpener can
regrind a blade with a different grind easily.
View newwoodbutcher's profile
newwoodbutcher
740 posts in 2845 days
#2 posted 04-12-2012 04:49 PM
Forrest has a blade set just for this purpose. I have one and am very happy with it
-- Ken
View gfadvm's profile
gfadvm
14940 posts in 2685 days
#3 posted 04-13-2012 02:22 AM
Freud has a 2 blade set that I love!
View Dusty56's profile
Dusty56
11819 posts in 3683 days
#4 posted 04-13-2012 03:04 AM
FTG....you don’t need to spend $100 on a specialty blade. I brought an older blade to my sharpening service and asked them to regrind the teeth to be a Flat Top Grind design. Cost me $8 at the time and still using it today : )
Perfect flat bottom and square edged cuts.
You can also Google “FTG saw blades” if you must have something new.
