Composite Decking problem
« back to Sweating for Bucks Through Woodworking forum
Forum topic by richgreer posted 434 days ago 1080 views 0 times favorited 10 replies Add to Favorites Watch
View richgreer's profile
richgreer
4472 posts in 1272 days
434 days ago
I know this is only a quasi-woodworking subject, but I need some input and i know this is almost always a good source.
I’m building a deck for someone. The customer wants composite decking, which I have never worked with and, frankly, don’t like much.
The decking has grooves down each side and it is secured to the joists with a special T-shaped thing that fits in the grooves and is screwed to the joist between each piece of decking.
When everything is in place I cannot tighten down the screws because my driver will not fit between the pieces of decking. The screws are #1 square drive. The problem is that the shoulders of the driver tip are not deep enough.
Is there a special driver tip for this? Am I not suppose to tighten them down?
Any advice would be appreciated.
Rich
10 replies so far
View nailbanger2's profile
nailbanger2
665 posts in 1341 days
#1 posted 434 days ago
Rich, I wish I could help for the numerous times you have helped me and others, but I’ve never worked with the stuff. At least this post will put you back to the top of the forum list (hopefully). Good Luck!
-- Wish I were Norm's Nephew
TopamaxSurvivor
13179 posts in 1873 days
#2 posted 434 days ago
A one piece driver should fit down in there. You must be using a magnetic with a replaceable tip???
-- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence
View waho6o9's profile
waho6o9
3070 posts in 774 days
#3 posted 434 days ago
I guess we would need to know what type of fasteners you have. Tigerclaw, Invis – ifast, Kreg, etc.
Mcfeelys has all sort of drivers, but you know that. Pictures maybe?
View Eagle1's profile
Eagle1
2042 posts in 1262 days
#4 posted 434 days ago
Kreg makes a setup for decking. I don’t know if it can be used for the composite or not.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
89146 posts in 1775 days
#5 posted 434 days ago
Most of them you screw down and slide the next piece on to the ones you just installed and then repeat. I’ve never had any that you have to screw in between the pieces. If your having trouble with just the open side then all you need is a longer bit.
View taoist's profile
taoist
88 posts in 689 days
#6 posted 434 days ago
The only “hidden” fastening system I ever seen on a deck is 1. the Kreg jig for decks where the fasteners are hidden between the decking planks and 2. A system that is screwed from underneath where the planks cross the joists.
With the Kreg system each plank is secured before the next one is installed next to it.
View SnowyRiver's profile
SnowyRiver
47635 posts in 1678 days
#7 posted 434 days ago
I agree with Jim, that you usually put down one piece, screw it in place, then slide the next one in and screw it down etc etc.
-- Wayne - Plymouth MN
View Mike's profile
Mike
261 posts in 885 days
#8 posted 434 days ago
Rich,
Check out Tiger Claws. I actually helped design some of these product so I am totally plugging it. I don’t work for the company anymore but try these. They work allot better than the junk you are using. Plus they are able to take allot me upheaval loading. I can send the research report if you want ;)
Tiger Claws:
http://deckfastener.com/pages/products.asp
The TC-G may work, but call them and ask for Dave Martel. Tell them that Mike Lepelstat sent you.
800-518-3569
-- look Ma! I still got all eleven of my fingers! - http://www.termitecrafts.com
View FirehouseWoodworking's profile
578 posts in 1471 days
#9 posted 434 days ago
I too agree with Jim. All the times I put down that type of decking, I screwed down one piece and then slid the next piece tight under the clips. Good luck, Rich.
Cheers!
-- Dave; Lansing, Kansas
richgreer
#10 posted 434 days ago
My problem is solved and I feel a little stupid.
The T-type hold-downs come with a bad of screws. In the bag of screws are a couple of driver tips that work perfectly. I just didn’t notice them initially.
Thanks for all the efforts to help.
Rich
