Prep of red oak before staining
Forum topic by WOODIE1 posted 04-11-2012 02:56 PM 11318 views 2 times favorited 8 replies Add to Favorites Watch
View WOODIE1's profile
WOODIE1
117 posts in 2400 days
04-11-2012 02:56 PM
I have searched but am overwhelmed with all the different replies. Finished a fireplace surround and bookshelf with the old HD red oak solid 3/4 wood.
Does red oak need any sealer or??? before using a stain? I am going with General stains either water or oil depends on avail color.
I would also like to use either a tung oil or wipe on finish to keep it simple.
Sealer? sand after sealer? Shelac? before stain? Any recommendations appreciated but please I am new so include a good description or name of the product as I get lost easy.
8 replies so far
117203 posts in 3698 days
#1 posted 04-11-2012 03:10 PM
I would use a grain fillerhttp://aquacoat.com/?p=257 sand it back apply some GF dyestain http://www.woodcraft.com/Family/2020491/General-Finishes-Water-Based-Dyes-.aspxand then a clear coat. I don’t think tung oil offers a lot of protection. This is much better.
http://www.amazon.com/General-Finishes-BASE-SATIN-COAT/dp/B001DSY7L6
no other sealer is necessary before or after.
View Sawkerf's profile
Sawkerf
1730 posts in 3189 days
#2 posted 04-11-2012 03:47 PM
It depends on what you want to see when you’re done. Red oak grain is pretty porus and will absorb quite a bit more stain then the rest of the board. That’s what makes red oak grain “pop” like it does. If you get more “pop” than you like, try a preconditioner or grain sealer so the stain doesn’t soak so deeply into the grain.
As always, practice on scrap before you commit yourself on a piece you’ve put a lot of work into.
WOODIE1
#3 posted 04-11-2012 05:33 PM
Thanks. I think I am going to skip the grain filler as I like the grain pop look. I would like to ton it down a bit but not eliminate it so I guess I will try a grain sealer.
Jim in the above are you putting an oil clear on top of water based dye?
I love wood working but always hated the finish process and this is from someone who used to paint cars.
I am going with a clear as we are now building a matching book case that will be exposed to sunlight.
Thanks off to Rockler to see what they have.
#4 posted 04-11-2012 05:56 PM
No problem putting the oil base over the waterbase. If you want to learn more about finishing Charles Neil has a great video set called Finishing A-Z beyond the books. It so happens he was a auto painter years ago too.
https://charlesneilwoodworking.3dcartstores.com/Finishing-A-to-Z--Beyond-the-Books-10-Disc-Set_p_8.html
View CharlesNeil's profile
CharlesNeil
2434 posts in 3991 days
#5 posted 04-11-2012 05:57 PM
Jim has it right, and no issue with the Arm R seal over Wb colorants, skipping the grain filler is a personal choice, his combo will do well ! I f your spraying a good top coat is GF Hight performance it also seems to have good heat resistence.
View Clint Searl's profile
Clint Searl
1533 posts in 2482 days
#6 posted 04-13-2012 06:22 PM
Red oak takes either dye or pigmented stains very well. Keep it simple by topping with a wipe-on oil poly that you can make by thinning poly from the can with naptha. You don’t have to get any more complicated than that.
View sandhill's profile
sandhill
2128 posts in 4044 days
#7 posted 04-13-2012 06:46 PM
What Jim said.
WOODIE1
#8 posted 04-13-2012 08:07 PM
Thanks for all the help. I made a couple test pieces. The rig was the plain Minwax Jacobean? 1 coat. I then picked up the Espresso General Finishes and did a test piece by itself. I had some left over on the rag so I went over the Jacobean and it looked good. Did one more coat and we have a winner.
I will post some pics over the weekend. Going with Jacobean Minwax 1 coat then 2 coats Espresso General with their satin clear. The bookcase is near a window so the added protection of the clear will keep me from watching all the time.
Thanks
