"Shallow cuts with the router", but how shallow?
Forum topic by KnickKnack posted 04-11-2012 09:51 AM 3228 views 1 time favorited 13 replies Add to Favorites Watch
View KnickKnack's profile
KnickKnack
1088 posts in 3560 days
04-11-2012 09:51 AM
Topic tags/keywords: router depth of cut shallow passes
I do almost everything with my router – mostly in the table, sometimes hand-held.
I’m familiar with the mantra of “many shallow passes”, and I do that.
I’m also a subscriber to the idea that “if it works, it works”.
I also suspect that I have a tendency to be ultra-conservative, and take more passes than I need to be, or “should” be, taking.
My question though, is about what the considered opinion of the more expert router users is as to “how shallow is shallow”.
Let me pose the question(s) in specific terms…
Presuming you have a decent router, and decent quality, sharp bits…
  1. If you’re cutting a simple slot with a 6mm (1/4”) bit in pine, at what depth of cut would you start to consider taking 2, rather than 1, pass?
  2. If you’re cutting a simple slot with a 6mm (1/4”) bit in something harder like oak, at what depth of cut would you start to consider taking 2, rather than 1, pass?
  3. If you’re cutting a simple slot with a 12mm (1/2”) bit in pine, at what depth of cut would you start to consider taking 2, rather than 1, pass?
  4. If you’re cutting a simple slot with a 12mm (1/2”) bit in something harder like oak, at what depth of cut would you start to consider taking 2, rather than 1, pass?
Do the answers differ depending on whether you’re cutting cross, or with, the grain?
I know there are no hard and fast rules, and that each piece of wood differs from every other, and that how it’s feeling should be the main guide, I’m just looking for some idea of what I “should” be doing, if I knew what I was doing.
Thanks in advance.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
13 replies so far
View Don Butler's profile
Don Butler
1092 posts in 3389 days
#1 posted 04-11-2012 10:36 AM
Knick Knack,
Cutting with the grain or across does indeed make a difference. Cutting across the grain usually is more difficult and may result in a breakout at the end of the pass.
But there are no rules or math that will answer the questions about depth of cut and number of passes. Not in my poor judgement, that is.
The method of making trial cuts in scrap is the best way to determine the answers. Even the differences between one board of the species to another can be significant.
So I offer this idea. Always have extra material for trial passes.
If it feels unsafe, for you or the material, don’t do it.
Finally, I offer this, don’t do anything you wouldn’t want to explain to emergency medical personnel.
Best regards,
Don
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View MoshupTrail's profile
MoshupTrail
304 posts in 2474 days
#2 posted 04-11-2012 10:51 AM
Listen to the wood and listen to your router. If the router slows noticeably then take less. If you can hear that crackly sound like planer tear-out, then take less. It should be a nice, smooth, not complaining sound. (Sorry, that’s really subjective, and I think you might have preferred a more concrete answer)
When doing end grain I always go around the piece in a counter-clockwise direction. So if there is any breakout on a side, I’ll be going over it when I rotate the board to the next side. But that only works when you’re doing all 4 sides.
-- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible.
View AaronK's profile
AaronK
1506 posts in 3458 days
#3 posted 04-11-2012 11:17 AM
you shoul;d be telling US, roger!
View Viktor's profile
Viktor
464 posts in 3412 days
#4 posted 04-11-2012 09:17 PM
Using ~ 1500 W router going along the grain I would start with approximately:
1. 10 mm
2. 7 mm
3. 7 mm
4. 5 mm
Probably little less across the grain.
But I also agree with what MoshupTrail said in post #2.
View RickRogers7's profile
RickRogers7
39 posts in 3031 days
#5 posted 04-12-2012 01:52 AM
I’m with Moshup Trail. I usually go by sound and the amount of force required to make the cut. Charles Neil does have a nice you tube video on bump cutting (another form of clim cutting) for dealing with end grain.
View Tennessee's profile
Tennessee
2870 posts in 2508 days
#6 posted 04-13-2012 05:06 PM
I use mainly a 2HP Bosch router running a 1/2” shaft, 1/2” X 1.5” long round twin carbide cutter to rout out the tonal chambers in my guitars. My rule of thumb is anything over 10MM, two passes. If I have to rout out say, 28MM, I would take three passes. I am mostly going both ways, against and with the grain since the tonal chamber is the approx. size of my pickguard. My router does not bog down at all.
I have taken as much as 15MM a pass, but only on softer woods, like walnut or ambrosia maple.
KnickKnack
#7 posted 04-15-2012 03:43 PM
Thanks for the replies.
I think I’m maybe being a little on the conservative side of expert wisdom, which is the right side.
What brought this issue to my attention was watching a few videos where the cuts they made just seemed effortless – like a knife through butter – mine seem more like the wrong side of a blunt knife through butter frozen down to almost absolute zero.
View Dan Lyke's profile
Dan Lyke
1520 posts in 4119 days
#8 posted 04-15-2012 04:12 PM
In pine, I might try for a quarter inch per pass, in harder woods I go for about 1/16”. I’ve tried more (like trying to cut a sliding dovetail in a hard wood in a single pass) and just destroyed the bit (in one case, shearing off the shaft). Now, for a sliding dovetail I’ll rough out with a straight bit first.
So about half of what Viktor posted.
View Rutager's profile
Rutager
27 posts in 2297 days
#9 posted 04-15-2012 04:26 PM
Hello,
I’ve always heard that a good rule of thumb is not to go deeper than the diameter of the bit on each pass, so bigger bits can go deeper, of course at a certain diameter the horse power of the router may come into play. I myself tend to be much more cautious on my cutting depth and usually try and do a final pass of 1/32” or less to get a cleaner finish.
Best,
Rutager
View gavinzagreb's profile
gavinzagreb
210 posts in 2313 days
#10 posted 04-15-2012 08:41 PM
Roughly, I’d say I do 5mm at a time in most cases. If it’s a really soft wood like pauwlonia, I might do 10mm at a time.
View Monte Pittman's profile
Monte Pittman
29216 posts in 2332 days
#11 posted 04-15-2012 08:53 PM
guess I am a conservative. I don’t go more than 1/8 to 3/16 of an inch at a time.
View eddie's profile
eddie
8565 posts in 2607 days
#12 posted 04-15-2012 09:01 PM
may be a stupid question ,i,m new and like to use my router dose motor speed play a part in this ?
-- Jesus Is Alright with me
117086 posts in 3571 days
#13 posted 04-15-2012 09:08 PM
Lot’s of good answers, I wouldn’t have a problem cutting a 1/4” with the grain in one pass or even across the grain in pine,as long as I’m not using a 1/16” router bit. Like the others have said listen to you router and check to make sure it’s not bogging down and what you cut looks like.It also has to do with what your routing(type of cut) and what shape your router bit is in. If I’m routing a profile along the edge of a board I’ll almost always take to passes just to insure a good clean cut. I would suggest taking some time to just experiment to see the results you get using different router bits on different woods .
