Anyone make their own W&H or Shop Fox moulding knives?
Forum topic by metaldr posted 06-18-2008 03:59 AM 1781 views 0 times favorited 3 replies Add to Favorites Watch
View metaldr's profile
metaldr
1 post in 3534 days
06-18-2008 03:59 AM
I have a Shop Fox copy of the W&H moulder that I am very happy with. I’ve made a couple of knives on a wire edm that I have access to. They have worked well on reclaimed pine but I don’t know the proper height to cut the knives. If they are too short I don’t get the full profile and if they’re too long the feed rollers don’t have enough pressure to feed the board. There seem to be a fine line between too long and too short. Anyone know how to determine the correct height for the knives? Thanks.
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3617 days
#1 posted 11-24-2008 04:37 PM
Could you measure a new set? Trial and error? Hope this works out for you.
9947 posts in 3552 days
#2 posted 11-26-2008 09:05 AM
It’s a trigonometric formula. if you can’‘t manage the math
you probably shouldn’t be grinding your own knives.
View CustomMouldingKnives's profile
5 posts in 1664 days
#3 posted 08-07-2013 07:02 PM
The correct formula is you need 1-1/2” from the bottom of the knife to the deepest part of the profile. Or this works also depth of cut plus 1-1/2”
-- Russ In Utah
